78 standard wheel lug nut sizes
  • Fix
    • May 2009
    • 384
    • Lake Orion, MI
    Search doesn't like 3 letter words, so I'm hoping someone knows the sizes of the front and rear lug nut on a 78E. I know they're bigger then any of the meager sockets I currently own.
    Thanks!
    Mike C
    Lake Orion, Michigan
    '78 XS1100E
    Here I am! Where are you?
    • 8892
    If you mean the axle castle nuts, the front is 22MM, rear 27MM.
    • Fix
      • May 2009
      • 384
      • Lake Orion, MI
      Yup, those are the culprits. I've got new tires to put on and rear brake pads to replace.
      Thanks!
      Mike C
      '78 XS1100E
        Thanks!
        Hi Fix,
        FYI a 7/8" (22.2mm) wrench is a sloppy "only if you are desparate" fit on a 22mm fastener.
        But a 1-1/16" wrench is the exact same size as a 27mm.
