Carb boots to engine head?
  • CA
    • Feb 2009
    • 267
    • Nashville, TN
    So I am trying to piece together the bike again for spring. I have rejetted accordingly to fit the pods and kerker. Just finished the valve adjustment. Put everything back together and have been trying to synch all day with a carbtune with no luck. My main issue has been horrible backfiring and erratic movement. I have synched the carbs before but this time was a beast! So noticed puffs of smoke at times coming from where the carb boot meets the head on one or two of them...so I took the carbs off and tightened the carb boots ( i did have them off for rehab...) it ran without popping for a while until rpm started to drop then it continued. I thought I may just be really lean but after letting ou t the IMS's a turn or two nothing helped.
    1. Should I use RTV on the carb boot surface??
    2. I re-used my exhaust gaskets...would that cause crazy backpopping?
    3. SOmething with the valve adjustment?
    4. Do i need to go back into carbs??
    I am pretty frustrated...this is taking longer than i had hoped. Everything that can go wrong has been....
    thanks
    1979 XS1100SF (4-1 Kerker, XS Pods, 145 mains, 45 pilots, drag bars, blacked out)
  • jmnjrpa
    • Jun 2009
    • 863
    • Lewisville, Texas
    Are
    you sure it did not jump time while adjusting the valves? BTW- I use black silicone but no gasket. Just run the bolt down almost snug and let set. Then after cure finish tighten.
    '81 1100 MNS - "Midnight XSpress"
    Original except:
    Big John
    • CA
      • Feb 2009
      • 267
      • Nashville, TN
      hopefully sure...
      Well my timing marks were perfectly lined up. I installed our new CCT jmnjrpa...rotated it by hand more than twice and everything was good..
      well I went ahead and used black silicone...except I went ahead and tightened...oops. Hopefully it will seal just as well.... If that doesn't fix it, then I will put in new exhaust gaskets...and trouble shoot from there..
      The problem is I don't know when I am going ot have time to do this. The semester is crushing in on me!!
      Anybody around Nashville wanna Help!!?? haha
      Thanks
      • jmnjrpa
        • Jun 2009
        • 863
        • Lewisville, Texas
        Sorry,
        In addition to having no time you are about to experience what has hit us today. We went from 72 at 6:00PM yesterday to 34 @ 6:00PM today. It was a straight slide with no warm up today. Wind gusts over 40 MPH and snow coming tonight. keep the covers up!
        Original except:
        Big John
