have ? about getting slide unstuck in carbs
  • Creedmore
    • Jan 2010
    • 5
    • Sheldon Missouri
    Do you all have any good ideas on how to get the slides unstuck on a Mikuni carb? 3 of out of the 4 are stuck fast even after trying to clean them with carb cleaner.
    Thanks
    Creed
    Kulley LeVaugh
    79 XS11 S "Rolling basket case"
  • tinman905
    • Aug 2007
    • 946
    • Orangeville,Ontario ,Canada
    Keep spraying them with carb cleaner they will loosen up sooner or later. Just don't use the strong carb cleaner it will ruin anything rubber on the carbs. Sea Foam works well to free up carbs too and it will not damage any seals or "o"rings
    BDF Special
      Heat and Expansion Rates: Carb body vs Slides.
      Heat Lamp if you got one.
      (Yeah...living here in the PNW where the sun isn't available leads to a lot of different ways and methods to simulate what the sun does naturally..)
      Place the carb bodies under the heat lamp like they're french fries at McDonalds for a while. The idea is that the bodies will expand first because they're exposed to the radiant light/heat. The slides will not get any heat/light and stay the same size until the heat from the bodies conducts to them from physical contact.
      May have to do this a few times with cooling periods in between. One of the safest/gentlest ways to unstick those slides or any "sensitive" parts.
      Getting impatient? If you're thinking of using a heat gun to do the job then be prepared to buy new rubber parts for the carb: Diaphragms, tees, butterfly shaft o-rings, etc. The temps of the heat gun are way beyond the melting point of those non-metal parts. Plus there's a fire/explosion hazard if there's any gas in the carbs. Fumes from any gas or residue get sucked into the heat gun and Kablooey.
      Put'em under the lamp and go to your happy place for a while: Outside the man-cave on a perfectly running XS1100 always works for me.
      • XSBell
        • Mar 2010
        • 29
        • Denver, CO
        PBblaster has worked for me on stubburn slides in the past. As stated topside though, careful with the rubbers.
        1980 XS1100LG
        • Creedmore
          • Jan 2010
          • 5
          • Sheldon Missouri
          Good idea about applying some heat to the carb bodys I will have to try that. I have been using PB Blaster with no success. I will try some mild heat and the Blaster and see if that works. If that doesn't work I guess I will have to find some other carbs.
          Thanks for the ideas.
          Kulley LeVaugh
          • XSBell
            • Mar 2010
            • 29
            • Denver, CO
            Make sure you use ALL the cuss words...some times twice. Tomorrow's a new day.
            1980 XS1100LG
