Rebuilt carbs, installed air pods, 4 to 1 Supertrapp exhaust. Bike starts and runs fine. Some popping through the pods until warmed up. Then idles nicely. Runs down the road, shifts fine through all the gears. But then, it will die out, usually in first and 2nd gear after the engine is thoroughly warmed up and won't start again for at least 10 minutes. After waiting the alloted time, the bike fires right up. Then, process repeats. Any ideas?
XS1100 bike dies after engine warms up
Tags: None
Sounds like a fuel tank vent is not venting. Try opening the fuel cap and running the same way to see if it still dies. If it doesn't, there's your problem.1980 XS850SG - Sold
-H. Ford -
Coils??
If you're sure it's not starving for gas, as in clogged filters, petcocks, gas cap vent hole etc. Check your coils.1980G Standard, Restored
Kerker 4 - 1
850 Rear End Mod
Automatic CCT
1980GH Special, Restored
'82 XJ1100 (Sold)
Automatic CCT, RC Engineering 4 X 1 Exhaust, K&N Pods, #50 Pilot Jets, YICS Eliminator. Sorely missed.Comment
Make sure your fuel lines are not kinked but I would agree that it sounds like a venting problem too!BDF Special
Dyno tuned to 98 hp at the rear wheel.Comment
+1 on the venting problem. It sound classic to me. Then again we could ALL be wrong.
Now that you mention it, I do hear a sucking sound coming from the gas tank filler cover after riding it for a while. Is this normal?Comment
sucking
Nope, these bikes don't suck.'81 1100 MNS - "Midnight XSpress"
Original except:
Big JohnComment
in a word "no". Next time you go for a ride, when the bike starts to die, pull over and pop the filler cap open, then see if it will start up again. If it does you'll have to take the cap apart and clean your vent.1979 xs1100 Special -
My Bike:Originally posted by fredintoonGoes like a train, corners like a cow, shifts like a Russian tractor, drinks like a fish, you are gonna love it.
[link is broken]Comment
