Broken Carb Float Post Fix!!
    OK, I wasn't talkin' out my a**.... I really did come up with a fairly easy fix, with one caveat; it's real easy if you buy a pre-made 'kit' from me, a bit tougher if you plan on totally DIYing it. But here's how it works, and complete directions on how to do it if you're so inclined.
    Typical broken post. This repair works as long as there's still some post above where the pencil is. Even if both 'tops' are gone, this fix will still work.
    What you need for material. Top row: piece of 16 gauge (.050" thick +/-) aluminum 1.05" x at least 1.5" (longer will make it easier to work). To the right it's cut to shape except the 'ears' are still long. Bottom row: Finished bracket and the new longer float pin (made from the shank of a 5/32" pop rivet). You also need a #41 drill bit.
    Dimensions. The critical ones here for proper fit is the 1.05" number, the .365" width of the 'ears', the 1.015" inside the 'ears' after you bend them, and particularly the location of the pin holes. All these need to be within +/- .002" for a good fit. The others you can cheat a bit, but do try to keep the 'base' where it contacts the gasket surface as wide as possible as it helps keep the bracket stable. Oh yeah, the new pin should be 1.170" long.
    Here's the only mod to the carb body. The posts are tapered slightly, so you need to file them 'straight'. File slowly and carefully; try not to take any off the upper part of the posts. When you have this right, the bracket will be just inside of the gasket. When you get this right, the float bowl should slide on with a slight interference. Don't force it. Check your pin location at this time. If it won't quite go in, file the post just enough until it does. You can file off any small bumps on the top of the posts if need be. DO check the float bowl to make sure it's 'flat' inside (see first bowl pic). And the hole in the one post is left over from a previous repair, so ignore it.
    Some (but not all) float bowls will have a 'ridge' here; if yours does, file it flat inside the bowl.
    Here's pics of the repaired carb. Again, if all your dimensions are right, the bracket will slide right on and the float pin will line up with the existing holes. Several things to note here: first, the bracket base should be in contact with the gasket surface. Next, notice the 'dimple' in the top of the bracket; this is what hold the bracket firmly down. This dimple contacts the bowl, and is made with a center punch. A firm hit is all that's needed; you want this dimple to be .030" high, no more. One last thing; I 'tweaked' the lower corners of the ears in as this will hold the bracket in place.
    This pic shows how the bracket fits into the bowl. If you did everything right, you should have .030" of the bracket hanging below the gasket surface, which is the thickness of the gasket.
    Now, for what it's worth, these fit perfectly on the five carbs I have available to me. So I have to assume that Mikuni held their tolerances pretty tight, but that's not to say someone doesn't have one that's 'odd'. I'm going to sell 'kits' consisting of the finished bracket, a new float pin, a 'file guide', and directions for $25 including shipping in the US. If you order more than one, each additional kit up to ten total will be $20 (minus the guide). If you're out of the US, same pricing but shipping will be on top and the actual amount.
    Mine are built by milling the aluminum to shape, then using a 'jig' to bend the ears and drill the holes, so I'm getting very repeatable results. There's still a bit of hand work involved even so. The only thing you need to install this kit is a file!
    I'll also send a free kit to anyone who will donate a dead carb body and float bowl to me. Neither need to be good, just as long as the bowl isn't bent/warped, the bowl fits on the body right, and the carb posts aren't gone more than noted. I've been using a 'loaner' from Foreda (Thanks Dale!) but he does want it back!
    One last thing; does anybody know what other bikes may share these carbs? I might put some of these up on Ebay (for a bit more money to non-forum people), and if they'll fit more than just the XS11, maybe I can make few bucks to feed my bike habit...
    Any comments or questions?
    '78E original owner
    Dammit! I still don't have the pic posting down right!!!
    Can somebody help me out on this? Please??
    '78E original owner
    • randy
      • Dec 2003
      • 4521
      Try this link...
      Store your photos and videos online with secure storage from Photobucket. Available on iOS, Android and desktop. Securely backup your memories and sign up today!
        OK, I wasn't talkin' out my a**.... I really did come up with a fairly easy fix, with one caveat; it's real easy if you buy a pre-made 'kit' from me, a bit tougher if you plan on totally DIYing it. - - -
        Hi Steve,
        Gawd, that's a clever fix. If ever Mr Clumsy works my carbs over I'll give you an order for sure.
        Would one need little sleeves between the float tang and the new wider pin holder to keep the float centred?
        All the XS series bikes had those carbs with only minor differences and from posts I've seen on other lists, just as much fun busting the pin posts off them.
        There's a whole slew of XS650s out there for a start.
          • 7941
          other bikes w/ Mikuni
          XS650 is the big one. Also XS750. XS850 has Hitachi, IIRC. I think the XS400 and SR500 are likely candidates, but you'll have to check that one. The list is probably long.
            • 7941
            Do you you think this fix will work if the post is broken off at the base?
              Hi Steve,
              Thanks Fred! I was hoping to come up with something that anybody could fab at home, but I soon figured out that the precision needed will be beyond a guy with 'average' tools. Sure, if you have a mill or a laser welder in your shop this is no big deal but not everybody does. But I think I got it half right, as install is nearly idiot-proof with just a bit of care. And one thing that may not be clear is the bracket is held in place by the float bowl; once the carb is assembled, it can't go anywhere. I promise better instructions with the kits.
              As to the sleeves, if you still have part of the original pin hole left you won't need any. I am going to find some brass tubing to include for those who are missing too much post, but most repairs won't need them.
              As a side note, Nicholson Files makes an aluminum-specific file. Works way better than a standard file and won't clog up if you're doing heavy material removal. Worth every every bit of the $15 or so they cost.
              '78E original owner
                It possibly could, but I wouldn't guarantee it. I think the repair would get much more finicky about fit. First, you would need at least some of the post left, say about 3/8" or at least 1/4". For precision, I think now you're looking at milling the flats on the posts and using a couple of small (4-40?) countersunk screws to attach the bracket. And taps this small break real easy, so this could be frustrating for a DIYer. Or maybe milling the sides of the posts and 'wrapping' the bracket around the posts. But this is now out of the realm of the 'average' guy....
                '78E original owner
                • 81xsproject
                  • 3185
                  • Fortuna, CA
                  Your fix looks great. I don't want to rain on your parade, but I have a couple thought about it; I don't know about everyone else, but the "typical broken float post" that I have seen is below the pin holes farther down (up if carbs right side up) on the posts. I don't see where the problem is with it being broken at the pin holes. For one, if the pins retain their factory shoulder near the head, you can use them broken with no problems. For two, if they won't stay or you are paranoid about only having one post, you can simply drill a hole in the post perpendicular to the pin orientation and use some thin gauge tig wire or some other wire to "twist tie" the pin down.
                  Again, great job. I am still dreaming up a fix for breaks lower on the post particularly those where you get the carbs and the broken piece is gone.
                  '81 XS1100 SH
                  Sep. 12th 2015
                  RIP
                    Oh, this is a limited-use repair. This was aimed at the guy or gal that has basic hand tools but no 'shop equipment' such as a good drill press or the skills to accurately relocate the pin holes, and only has one or both of the pin holes missing but the rest of the post is still there. For a lot of people, this kit will easier/faster than rounding up the stuff to do a 'other' fix and actually doing it. You have to admit that this is a better repair than tie-wire or gobbing JB weld on it. And certainly easier to do than the other kits I've seen.
                    As far as fixing carb posts that are broken lower and/or have missing parts, that wouldn't be that tough but now you're talking precision machine work on the carb body itself. If there's enough interest, I could build the needed tooling/jigs but instead of the roughly 35 minute time to fab a 'kit' (over and above the time spent to figure it out and build the tooling), now your talking probably an hour or better per carb. Unfortunately, these carbs aren't worth that much yet; as long as you can still buy a full 'rack' for about $100, who's going to spend $50-60 to fix just one?
                    I should also state I'm not a professional machinist. I'm completely self-taught and have some cheap chinese machine tools that are accurate enough to do this sort of thing; no CAD-CAM here! A pro could probably turn these out for about $1 each once you have the setup, but amortizing the cost of his $50K machine would no doubt run the price up some...
                    '78E original owner
                    • Geezer
                      • May 2003
                      • 2985
                      • Willamina, Oregon 97229
                      Go over to Columbia Cycle Salvage (they're about an hour drive from you and take pix of your work. I'm sure they'll sell you some F'ed up carbs cheap and even be willing to save some for you in the future.
                      Geezer
                      • res1uqtp
                        • May 2009
                        • 84
                        • East Central IL
                        Just out of curiosity what is the common fix when you DO have the posts? I happen to have two carbs in this state and have all the broken pieces. One has both posts broken. One has only one post. All pieces accounted for.
                        My Stable:
                        2006 Triumph Bonneville Black
                        1979 Yamaha XS11 Special (2 of them)
                        1982 Yamaha XS400 Heritage Special
                        1981 Suzuki GS550 E
                        1976 Honda CB550F Supersport
                          • 7941
                          Backtrack through this thread. MOTORCYCLECARBS>COM
                          will weld them for you.
                          • xj11john
                            • Jun 2005
                            • 440
                            • Lafayette, TN
                            Hey Steve, would your kit work for a XJ750 Maxim?
                            I have been cleaning a carb for a buddy with a XJ750 maxim, the carb is a bit different but would your kit work for it? Have you found out what carbs it will work for yet? I could measure the post or whatever.
                            If you can get back to me soon it would be good since he want to sell this bike and people want to hear it run, thanks in advance, great fix by the way!
                            '82 Xj1100j
                            "Ride for the Son"
                            John
                              John, you'd have to check to see if the dimensions of the posts are the same; specifically the .838" from the float bowl gasket surface to the center of the hole and the 1.015" outside-to-outside distance on the float posts. If these match up (within +/- .002") and the posts have the 'step' at the top you can see in the pic, it would probably work. If not, it would be extremely hard to mod this to fit and keep the needed precision. Not much help, but I don't want to sell you something that won't work. Fixing a broken post can be very finicky...
                              '78E original owner
