Special v. Standard: Interchangeable front fender?
  • draketrumpet
    • Feb 2010
    • 387
    • Norman, OK
    I know the fenders are different on specials and standards (hence tkat makes two braces), but are they interchangeable from one bike to the other. Is there any drawbacks about doing that.
    TIA for helping a noob.
    You CAN make a special fender work on a standard, but NOT the other way around. The sliders on the special and standard are two different diameters, hence the two fork braces.
    Best bet is get the proper fender, or go for an aftermarket plastic/fiberglass fender and make your own mount. either way, the Tkat brace is a MUST if you like riding a little ( or a LOT ) faster than the posted speed.
    • draketrumpet
      • Feb 2010
      • 387
      • Norman, OK
      Thanks.
      I think I'll just let this one go to whoever bid 9 bucks for it then. The guy selling it said it came off a bike with a VIN of "3j6 002050" which I believe is a special.
      Maybe it won't go for 9 bucks anymore.
        The two fenders are fairly easy to tell apart; the Special fender is a one piece stamping, the Standard is two (the mounts are spot welded to the fender).
        Norman, eh? My mother escaped... uh, I mean moved from there, but I still have cousins in the area. Know any Calverts?
        '78E original owner
          Hi Drake,
          it's my understanding that the fenders don't swap, not because of different fork slider diameters( although that may also be a reason) but because the Standard front axle is under the slider while the Spacial front axle is on the front so that the fender blade's arc won't match the wheel if you swap them.
          • draketrumpet
            • Feb 2010
            • 387
            • Norman, OK
            I know of some. At my law school there is a Calvert Chair and a Calvert Moot Court competition. I'm fairly new to the area though and haven't met too many people outside of law school.
              I doubt if those are related... They were mostly poor dirt famers. If there's any rich Calverts (that can afford to endow a chair), I never heard about them...
              '78E original owner
                Yep, I put a Standard front fender on Special forks before. To make the arc correct, the rear mounting holes have to be re-drilled. That requires getting rid of the spot welded on washers first which is a PITA. A Special fender to Standard forks, I've never tried. I know a Standard fender can be made to work with FJ forks though.
