Valve shimming question
  • Valve shimming question
    so after rebuilding an xj1100 from the ground up i finally got my cam chain tensioner in today so i got all the timing down and after that i started the valve shim. the intake valves however have almost no clearance. i also rotated the whole cam thinking that maybe i had the cam lobe in the wrong position but even to the eye i could not see a shimmer of light. and specs call for between .16-.20 mm of clearance. another thing is that when i pulled the head off i recorded all of the lifter pad and the exhaust and intake are all almost identical like it intake lifter pad for cylinder one is 285 along with the exhaust pad. also i remember but did not record almost all of the valve springs where about the same length and all in spec. i'm just trying to figure out if maybe the PO increased the lifter pad as of a mistake of not realizing he had 4 bent intake valves the whole reason i pulled the head off in the first place. also before i started working on it this winter i rode it around after i replaced the valves and the bike was running pretty rich and the idle setting screw was almost tightened down could this be cause the lack of clearance in the intake valves giving the engine more fuel then it should? i just want to ask the 1100 gods before i start buying smaller pads
    Well, for starters, on the XJ, the intakes are shimmed to .11~.15mm and exhaust is .21~.25mm.
    You will need to get the thinnest shims you can find to give you a place to start. If you replaced the valves, the clearances the old valves had won't be anywhere near the same. Did you lap the new valves?
      Secondly the "idle screw" does not have anything to do with the valve clearance. The thickness of the valve shims can only affect the valve clearance.
      BDF Special
        yes i did lap the valves and now that you say that it makes perfect sense also tin man i was just saying about the idle mixture screw cause the bike was running super rich and if the valve is letting in more fuel wouldn't that cause it to run richer then it is suppose to
          Running rich could be lots of things, from the mixture screws, to the float levels, clogged jets, float needles not seating...
          From the factory, those carb mixture screws were capped off. Apparently someone has removed that cap over the years? Did you leave the YICS tube intact? You'll need the YICS tool to sychronize the carbs if that's the case.
            One more correction - there are no 'gods' here. Most of us are just regular joes that play mechanics on the internet. There are some pros here, though.
              Pros VS Joes.
              Hi. My name is Joe.
