Adjusting the Cam Chain Tension
An out-of-adjustment cam chain can cause the bike to run poorly and vibrate. To adjust the tension, locate the tensioner on the front of the engine between cylinders 2 and 3 - it's that little do-hickey protruding from the cylinders with a bolt sticking out the left side. Remove the engine case cover over the timing plates and use a wrench to manually rotate (clockwise) the engine until the timing pointer aligns with the "C" on the timing plate. Then loosen the locknut on the cam chain tensioner, loosen the bolt, then retighten the bolt and then the locknut (specified torque is only about 5 ft/lbs so don't overtighten), and replace the case cover. That's it.
so i need help locating the item in RED
