Mike XS Coil Upgrade parts list help
  • kevxs
    • Apr 2009
    • 353
    • toronto
    Hi guys, finally getting around to replacing my coils on my 79SF. Just want to make sure I'm ordering the right parts and not missing anything . . .
    2 x High Output Replacement Ignition Coil
    Part #17-6803
    2 x Spark Plug High Tension Wires
    Part #23-2902
    4 x NGK Resistor Spark Plug Cap (5K Ohms)
    Part #23-3113
    is this correct?
    Here is a quick link to the parts site. . .
    http://www.mikesxs.net/products-27.html#products
    thanks, this forum rocks
    1979 XS1100SF 37000km
    Green Dyna Coils
    Stainless Brake Lines
    1973 CB100
    kevXS
  • lakecountrydave
    • Aug 2007
    • 384
    • Phoenix, AZ
    I am not sure if they are the correct caps, but NGK Plug Cap - LB05FP 5k Resistor*** (23-3113) are out of stock according to the web site.
    Dave
    1979 XS1100SF Special
      Go for the NON RESISTOR plug caps. You can then buy the resistor type plugs (much easier to find!) and run them, including the iridium plugs! Make sure they are NOT the oem type, so you don't need to pull the ends off the plugs! That is what I've done on my daily ride. Plugs and coils work great, I just need to get the carbs running correctly.
      • Da-Bubble
        • Jun 2006
        • 353
        • Oklahoma City, OK
        I have a 79SF that I've done the MikeXS coils on. You do not need those plug wires or caps. Just buy the coils then go to Autozone or whatever you Canuks have and buy some coil wires. They usually sell them individually and you can sometimes pic your colors. I have 8mm coreless and they work great...it was cheap too. Good Luck!
        1979 XS11 Special (slightly modified)
        dubbed the "Mad Mosquito"
        MikesXs Pod Filters
        MikesXs 35k Coils
        8mm plug wires
        42.5 Pilots 142.5 Mains
        (Carb tune by GNEPIG Performance)
        Kerker 4-into-1
        Shaved emblems
        Progressive frt springs lowered 1.5"
        Progressive 11.5" rear shocks
        Harley Dyna rear fender chopped
        Custm side mt tag (apparently illegal)
        Custom Dual Headlights
        Lots of time and hard work.
        • MindWebs
          • May 2009
          • 431
          • Baldwin, WI
          Da-Bubble, nailed it
          yup, yup, yup,....
          what he said...
          yes if you shop around you may be able to find a better price on the bits n pieces..
            • 8962
            Kevxs, those caps from Mike's will work, but the correct ones for the 2 inner cylinders are these, they're a bit longer to keep the wires from touching the head. They are the type for the removed tip plugs though...
            http://www.parkeryamaha.com/ngksparkplugcapxb05f.aspx
            • kevxs
              • Apr 2009
              • 353
              • toronto
              Fast shipping!
              thanks for your help guys, i ordered all the stuff from mikeXS, gonna try it with the 4 90° plug caps, i wanted to order everything from 1 place if possible. anyways i ordered the stuff and it arrived the next day! unbelievable
              Green Dyna Coils
              1973 CB100
              kevXS
              • Giggity
                • Mar 2009
                • 113
                • Longmont, CO
                I just bought the long ones from my local Kawazuki shop. Paid full retail though
                1979 XS1100 Standard
                Putting it together........
                • 79XS11F
                  • 3563
                  • Ottawa, Ont. Canada
                  I'm running Accel coils, wires and caps on my hop up bike with what I think are standard plugs. They are Champion cross reference replacements for what would have been stock. Isn't the resister type plugs or caps just to prevent interference with radios?
                  Rob
                  KEEP THE RUBBER SIDE DOWN
                  1978 XS1100E Modified
                  1978 XS500E
                  1979 XS1100F Restored
                  1981 Suzuki GS1100
                  1983 Suzuki GS750S Katana
                  1983 Honda CB900 Custom
