Petcock Sealing Washers
  • MrOzz
    • Aug 2008
    • 782
    • Massachusetts
    I have to replace the washers on my petcock. The ones that go on the screws that hold the petcock to the tank.
    I was going to order them from bike bandit. But I found some on mikesxs.
    Found here http://www.mikesxs.net/products-34.html#products
    Part #20-0018.
    They are a little cheaper on mikesxs. Also I was going to order the pod filters from mikesxs, so one stop shopping. Does anyone know if they will work, or has anyone found something like this at their local hardware store, autoparts store that works?
    Thanks all,
    Ozz
    1980 XS 1100SG
    Dyna 3 Ohm Hi Output Coils
    Pod Filters
    DynoJet Kit
    T.C.'s Fuse Block
    V-Max Auto CCT
    P/N 20-0018 will work fine, I've used them before. If you need them right away, Ace Hardware has the fiber washers that work also.
    • MrOzz
      • Aug 2008
      • 782
      • Massachusetts
      Thanks bikerphil.
      1980 XS 1100SG
      Pod Filters
      DynoJet Kit
      T.C.'s Fuse Block
      V-Max Auto CCT
      • Yard Dogg
        • Mar 2010
        • 884
        • Tri-Cities, Wa
        I went to Ace and found vinyl washers that work good.
