I've had an irritating problem since I've had this bike. Every time the lower half of my engine gets wet, it starts running like hell and cutting out severely. I know I have wires running under there from the generator which is probably to blame, but I was hoping to get some feed back before I tear it apart. I don't want to end up destroying factory wiring just to be wrong.
I noticed it the first time I washed it. Then again when it was rained on. At first I thought it was the wiring coming from under the headlight assembly. But now I've found that if I wash only the bottom half of the engine it still cuts out. I've sealed the generator cover and pulled the starter to see if it could be the problem, but it still does it. I'm just curious if anyone might know of a common flaw that would cause this.
