xj carbs
  • xj carbs
    i no i no this might not be the right place for this but i need it seen. I am looking for two butterfly s (blades) for my carbs. Or a rack of carbs for my Xj.PO decided to bend the shj_ out of the two outboard carbs. Can not get the thing to settle down enough to idle proper or accelerate either.Any info or help would be greatly appreciated.
    1982 XJ 1100
    i have some carbs sitting around that might share butterflys. I'll try to check in short order.
    K. Johnson
    -1978 XS750SF - brought back from the dead with carb
    triple clean and boots
    -1982 XJ1100J - brought back from the dead by
    replacing motor after throwing #4 rod
    -1985 XJ750XN - shim job, oil change, ride. not bad for
    $500 including new rear tire.
      If kjohnson does not have the two butterfly s (blades) I do.
      David
      1981 XS1100 Special
      Previous Bikes
      1999 Honda Goldwing Aspencade 1500
      1983 Honda Goldwing Aspencade 1100
      1982 Honda CB900c
      1984 Honda vt750 Shadow. My son's bike now.
      1984 Honda vt500 Shadow
        kjohnson, I am looking for a #4 carb body (farthest to the right while facing forward) for an xj1100. do you have one?
        David
        1981 XS1100 Special
        Previous Bikes
        1982 Honda CB900c
          chevy45412001:
          Unfortunatly, the butterfly plates i have are not the correct size.
          davidsymons53
          I don't have any spare #4 carbs. Sorry.
          K. Johnson
            K. Johnson, thanks for your reply.
            David
            1981 XS1100 Special
            Previous Bikes
            1982 Honda CB900c
              chevy45412001, what is the number on the butterfly disk?
              David
              1981 XS1100 Special
              Previous Bikes
              1982 Honda CB900c
                not for sure what number is on them.I do know they had to be from xj though.I think they are 34mm.Could be wrong on that one though.Jerry you would know?i would also go for the whole rack,but those are getting a little harder to find these days.Did spot some on a motorcycle bone yard site to the tune of 225 plus shipping (ouch!)
                1982 XJ 1100
                  I would have to check. Don't know off the top of my had. I'll see if I can dig out the bike and take a look.
                  Jerry Fields
                  '82 XJ 'Sojourn'
                  '06 Concours
                  My Galleries Page.
                  My Blog Page.
