Originally posted by TomRodgers
View Post
Better info needed on how to sync.
Well, last night I did some serious bedtime pondering. And I think I'll take a scientific approach to the bench sync. I know my engine is in great shape, but I only have a vacuum gauge to work with. Since my carbs are completely clean and fuel residue free, I'm gonna rig up a vacuum cleaner as my vacuum source to sync the carbs. I think this will be a much better approach because the vacuum will be consistent and to start with I can completely close off my pilot jets. I know I can get em dead on that way. Then I was thinking of rigging up a small suction cup to a vacuum line, putting the suction cup over the little port hole for the mixture screw, and adjusting them that way. That part is probably ridiculous but don't bash me, I just want to try it. Last thing I'll do is a fuel level check. I'll let you know how it all turns out in a few days.
FOR ANY OF YOU WHO WOULD LIKE TO TRY THE VACUUM CLEANER APPROACH TOO, DON'T DO IT UNLESS YOUR CARBS ARE COMPLETELY RESIDUE FREE AND CLEAN CLEAN! I once read of some poor 16 yr old kid who tried to siphon gas out of a car with a vacuum and blew himself up. Poor guy."The Hooligan" XJ1100, Virago Gauge Pods, Screaming Eagle Mufflers, K&N Filter, hand made rear fender, side covers, and solo seat, round bar conversion, small headlight, tail light, and cat eye turn signals, chip fuses, rewired the right way.
Originally posted by jeepsterluv View PostWell, last night I did some serious bedtime pondering. And I think I'll take a scientific approach to the bench sync. I know my engine is in great shape, but I only have a vacuum gauge to work with. Since my carbs are completely clean and fuel residue free, I'm gonna rig up a vacuum cleaner as my vacuum source to sync the carbs. I think this will be a much better approach because the vacuum will be consistent and to start with I can completely close off my pilot jets. I know I can get em dead on that way. Then I was thinking of rigging up a small suction cup to a vacuum line, putting the suction cup over the little port hole for the mixture screw, and adjusting them that way. That part is probably ridiculous but don't bash me, I just want to try it. Last thing I'll do is a fuel level check. I'll let you know how it all turns out in a few days.
The point of carb syncing is to get all 4 cylinders pulling the same amount at idle, which will keep them pretty much even at all settings. You cannot do this off the bike with any chance of having it good enough to be done with, and you will spend far more time trying to use a vacuum cleaner and will still have to sync them on the bike, your going to have wasted your time.Cy
I'm sure your right. I know the fuel air won't work. But the throttle flaps will be adjusted better than my engine. Engine vacuum between 4 cylinders will vary and so will everything after that. I want to make sure the carbs are all pulling the same vacuum to begin with. The fuel air I will do by ear. I'm more experimenting with it at this point. I'm laid off, bored, and have no where to go on it right now anyway."The Hooligan" XJ1100, Virago Gauge Pods, Screaming Eagle Mufflers, K&N Filter, hand made rear fender, side covers, and solo seat, round bar conversion, small headlight, tail light, and cat eye turn signals, chip fuses, rewired the right way.
I only have one vacuum gauge as well and here is how you do it.
1. Go to the auto parts store and buy 5 or 6 ft of vacuum hose sized to fit the vacuum nipples on the carb boots. I can't remember the size.
2. On the way stop at a pet store, go to the fish section, buy an airline splitter with at least 4 taps. You want a good brass or other metal one, not the cheapy plastic one.
3. Hook your vacuum gauge to the "in" port of the splitter, it won't have a valve.
4. Hook each "out" port of the splitter to one of your carb boot nipples.
5. Open the valve for the carb you want a reading on, I think I start by finding out what #3 is.
6. Now close #3's valve and open #4's, adjust the screw till #4 matches what you saw for #3.
7. Now double check by closing #4 and opening #3
8. Repeat 5 - 7 for other combinations of carbs until your balanced.
This valve assembly I got
Other option is build a DIY manometer, I'm sure if you search you'll find directions;1979 xs1100 Special -
Originally posted by fredintoonGoes like a train, corners like a cow, shifts like a Russian tractor, drinks like a fish, you are gonna love it.
[link is broken]
Originally posted by jeepsterluv View PostI'm sure your right. I know the fuel air won't work. But the throttle flaps will be adjusted better than my engine. Engine vacuum between 4 cylinders will vary and so will everything after that. I want to make sure the carbs are all pulling the same vacuum to begin with. The fuel air I will do by ear. I'm more experimenting with it at this point. I'm laid off, bored, and have no where to go on it right now anyway.1979 xs1100 Special -
[link is broken]
You just can't get around it. One thing I can't understand is those who come on here and ask for advice about a procedure, and the proceed to ignore the advice they get and go do their own thing anyways. I mean, why bother asking for info on how to sync and then go do your own thing? If you really don't think you can do it with a single gauge, there may be someone close enough to you to come by with a set and assist. I know if there were someone in this are that needed to sync their carbs and didn't have guages I would be willing to drop by and assist with my set of guages, or have them drop by my place to do it. It would be better to not bother doing the task at all, then to now do it right IMHO.Cy
Did you read anything I said? I ****ing know what you are saying. Take a midol and have a nap. Have a smiley!"The Hooligan" XJ1100, Virago Gauge Pods, Screaming Eagle Mufflers, K&N Filter, hand made rear fender, side covers, and solo seat, round bar conversion, small headlight, tail light, and cat eye turn signals, chip fuses, rewired the right way.
The Perfect Storm
Originally posted by jeepsterluv View PostI'm laid off, bored, and have no where to go on it right now anyway.
Could be worse: You could be retired with the time and the money but stuck in WA on the other side of the mountains where the weather conspires against you each time you do wanna hop on a fully functional XS.
The folks that live in the lower latitudes with fairer riding weather and sunny dispositions to match are such a nuisance at times.
They can't help it though: They probably rode their bike in the last week.
That being said, do take care you dont hook your vacuum cleaner to the wrong spot and pull your carb diaphragms so hard you tear them or something. I guarantee you that vacuum cleaner is pulling easily three times more than the engine will.
As previously stated, the entire point of the synchronizing is that, as you stated, each of your 4 cylinders will vary with the amount of vacuum it pulls at idle when given the same amount of fuel at any given mixture.
The tuning process is designed to give your cylinders their own individual preferred mixture of fuel, and the synching process is designed to get all four cylinders pulling the same vacuum (note this is not a specific vacuum level but the SAME vacuum level as others have stated.)at idle by adjusting how much of their preferred mixture they are getting.
The fun part is that once you synch them, then you tune them to their preferred mixture, it changes how much vacuum they pull so you have to go back and readjust how much they get, which can then change what the preferred mixture is again....round and round the horsey goes...
In all honesty, your making a mountain of work out of the "bench synch" and can not possibly attain any closer result for it. But, your bored and interested, don't break anything and have fun.Life is what happens while your planning everything else!
Originally posted by jeepsterluv View PostDid you read anything I said? I ****ing know what you are saying. Take a midol and have a nap. Have a smiley!Cy
Originally posted by Larrym View PostYup. I can relate. Having a superbike and time on your hands is usually a great combo. That "laid-off" thing puts a kink in the revenue stream though.
Update: While writing this message I got an IM right after I pressed save telling me that my forks have arrived. Yay!Cy
That's right. I'm not trying to waste people's time, I just think out of the box. I have a theory. If 1 cylinder pulls more vacuum than another, it makes more sense to me to sync the carbs identically for longevity. Because in reality that higher compression cylinder is pulling more air. So if I cater to the cylinder by changing the airflow through the carb to allow more air, then the piston rings and valves will experience even less blow by than the others and will keep compression longer than the others. Also I would have to open up the air fuel mixture screw to allow even more fuel into the cylinder, so now I will have more fuel and more air going into that one cylinder making a bigger pop. But if I make sure the carbs are allowing the exact same air flow to all cylinders, then maybe the cylinders will wear out more evenly over time. I'm gonna make it a science project."The Hooligan" XJ1100, Virago Gauge Pods, Screaming Eagle Mufflers, K&N Filter, hand made rear fender, side covers, and solo seat, round bar conversion, small headlight, tail light, and cat eye turn signals, chip fuses, rewired the right way.
