Finally a little luck with a bad carb
  • kjohnson
    • Aug 2007
    • 202
    • Wetaskiwin, Alberta, Canada
    Well ok, the whole carb wasn't bad. In fact it was working quite well with one exception: a buggered idle mix screw on the #1 carb. All the others came out easily while cleaning, but #1 basicly just shattered. Yes the screwdriver was a proper fit, made sure of that before I started.
    After attepting to get the srew out with heat, penetrants, oils and what was left of the top, I thought I was going to have to either replace the carb or just suffer with it as is.
    The idle mix needed to be set, so I decided I'll try easy-outs. I started with a 1/4" drill (just fits snugly in the reccess) bit to "flatten" out what was left of the top. Then I drilled down the middle of the screw with a 5/64" bit, basicly drilled about 3/4 of the threads worth deep. Inserted a #1 screw extractor/easy-out/whatever, gave it a tap and it came out just as easy as the other screws.
    Now all I have to do is wait for the replacement to get here so I can re-assemble everything completely. I feel a little better about the bike now and a little luckier in general.
    Now to train the 9 month old to put the tools back when he's done eating them...
    K. Johnson
    -1978 XS750SF - brought back from the dead with carb
    triple clean and boots
    -1982 XJ1100J - brought back from the dead by
    replacing motor after throwing #4 rod
    -1985 XJ750XN - shim job, oil change, ride. not bad for
    $500 including new rear tire.
  • mack
    • 2411
    • Ontario, Canada
    Right
    Good luck with that, mine 16, 14 and 11 and I can't get them to learn how to turn a light off. By the way they don't stop eating at all once they hit their teens.
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
