I could learn to live with this, since it is not an issue that affects most everyday riding, but I don't want to.
Incubus, my XS1100F, has a clutch issue. While the clutch grabs fine off the line and also grabs real well at the lower end and though most torque ranges, it tends to slip at high rpm. I'm talking 7500 rpm and up. This upper range is accessed rarely in regular riding, but that's where I keep the adrenaline. I like to be able to get to it when I want.
I have another complete clutch in good condition, so I could do TC's extra steel plate mod. I also could order new stock, barnett or heavy duty clutch springs and probably fix it. However, I like the softer clutch feel that comes with regular stock springs. I have heavy duty springs on my other XS1100F and I am not fond of the workout my left hand gets.
When I got the bike running last summer I checked the clutch pretty thoroughly. The friction disks were well within spec and the clutch springs measured as if they were new. I do not know if the steel in the springs loses some of its springiness over the years.
I also use standard dino type oil.
What is the most likely way to fix this issue without making my bike less pleasurable to ride?
Thanks, y'all.
Patrick
Thanks, y'all.
Patrick
