Engine Progress
  • mack
    • 2411
    • Ontario, Canada
    Engine Progress
    This is cleaned and polished with one coat autosol. Will try buffing compound #5 & #6 later. Looks like all the coon sh..t is gone.
    This is all I'm stripping and polishing this year. Time to start putting it back together.
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
  • tinman905
    • Aug 2007
    • 946
    • Orangeville,Ontario ,Canada
    Wow! that's a nice looking engine. You've done a great job cleaning and polishing. It's nice to see someone put the time and effort into our bikes. It would be nice to see you at the XSNorth rally so we can all meet you and see the great job you have done.
    BDF Special
    • petejw
      • 2269
      • sydney australia
      That looks really nice,
      something i want to do to mine one day.
      pete
      new owner of
      08 gen2 hayabusa
      former owner
      1981 xs1100 RH (aus) (5N5)
      zrx carbs
      18mm float height
      145 main jets
      38 pilots
      • cywelchjr
        XS-XJ Super Guru(Deceased)
        • 4450
        • Sacramento, CA
        I can imagine the amount of work it's going to take to keep it looking like that though. Unprotected polished aluminum can take a lot of work to keep it looking good. That's why they paint the stuff from the factory.
          I like the custom engine stand....
          '78E original owner
          • Southhill101
            • 45
            • Calgary, Alberta
            Mack,
            What Autosol product did you use for cleaning? Those fins look spotless, always a pain to clean.
            Cheers,
            1981 XS1100 Special
            Saddlemen Seat
            MAC 4 into 2 Turnouts
              You REMOVED the cam chain tensioner!!! Be VERY CAREFUL when you put the tensioner back on!!! I hope you had the engine at TDC BEFORE you removed it, and did NOT turn the crank AT ALL with it out!!!!
              • foreda
                • 949
                • Southwest Louisiana
                Engine stand
                I don't suppose you would have a drawing of the engine stand? Engine looks great! What kind of pads or wheels did you use between the fins?
                78 XS1100E Standard
                Coca Cola Red
                Hooker Headers
                1979 XS1100 Special
                1980 XS Standard
                2006 Roadstar Warrior
                • 79XS11F
                  • 3563
                  • Ottawa, Ont. Canada
                  That's looking grest Mack. Do post the plans for your stand.
                  Rob
                  KEEP THE RUBBER SIDE DOWN
                  1978 XS1100E Modified
                  1978 XS500E
                  1979 XS1100F Restored
                  1981 Suzuki GS1100
                  1983 Suzuki GS750S Katana
                  1983 Honda CB900 Custom
                  • mack
                    • 2411
                    • Ontario, Canada
                    Thanx guys
                    It looks better in photo's than it really is, for some reason the pitting left behind from the rust doesn't show up. If you really want to see a fantastic job, go to 79XS11F web site. Robs motors look like chrome. Anyway I used everything from dental picks and Q tips to sand paper on wooden shims. Rolox pads with a die grinder and various dremmel attachements. I went to Papa Johns tool box and bought all the dremmel stuff(wire brushes, various buffing apparatus) by bulk. Much cheeper than Home depot or lowes.
                    Not to worry about the tensioner, what your looking at is basically just a shell. The internal workings are laid out in several rows on two large tables to the right. The stand is grossly over built. I didn't know how much the engine would weigh so I figured bigger is always better. The motor is tipped slightly forward on this one so all the oil will drain out. I can post the spec's if your interested but I'm almost computer illiterate if you haven't noticed during my attempts to post a picture. I"m not sure how to get the dimmensions in but I'll have my ten year old give me a crash course and I'll see what I can do. Just give me a little time.
                    As for maintaining this shine. I really had no choice but to take a layer of aluminum off to remove all the rust and stuff. As foreda can attest, I was too embarassed to post any pre-restore pictures as it was in such a bad condition. I am the original owner so no matter what, it was my fault it got to that state so now I'll have to do what it takes to keep it looking good. A lot of wax I'm guessing.
                    Where would the NE rally be held this year?
                    mack
                    HERMES
                    original owner
                    81 XS 1100 LH MNS
                    SPICA
                    78 XS 11E
                    IOTA
                    613-398-6186
                    • ManitoulinLad
                      • 358
                      • Manitoulin Island,Ont.,Canada this is in Lake Huron
                      Hey Mack: That motor looks fantastic! If its a reflection (no pun intended) of what the rest of your bike will look like I imagine your restoration build will be excellent. Please post a pic when you got it all done - great work - Dan
                      '81 XS1100 LH - Midnight Special - been lookin' a long time for this one.
                      1179 big bore kit, 80SG motor
                      Rebuilt head, valves
                      TC Bros Forward Controls (Brass Pegs)
                      Tkat Fork Brace
                      T.C. Spade Fuse Box
                      Dyna Coils & wires
                      Mikesxs shocks,controls,& bars (special)
                      ISO grips with stelleto ends
                      4 into 1 black Bassani exhaust
                      Bridgestone Spitfires
                      Tuned by Tinman905
                      & a will to keep it.
