So, while I'm cleaning the motor I, rotate the it until I feel where the top of the piston stroke is. I look down at the timing mark and this is what I see. If you look closely, you'll notice that the pointer is not where it's supposed to be. The vacum hose is off. Is this just a matter of moving the pointer. Also, while i'm in the process is there any maintenance I should do to the thing while the cover is off. P.S remember I'm not a mechanic so try to stick to technical terms like, "thing ma bobs" and "do hicky's"
![](http://i946.photobucket.com/albums/ad305/mack-055/XS%2011/Timingmark.jpg)
