Will a low battry keep an XS11 from starting?
    replied
    Where in the hell did that come from?
    Step slowly away from the bong...
    Leave a comment:
    replied
    The Plot Thickens
    "The Partridge Family was neither a bird or a family...please discuss at will "
    It was just good wholesome entertainment coming to us free via the idiot box. Not much in the way of plot but I'd tune in just to see what shenanigans Susan Dey was up to.
    BTW, Mrs Partridge would have never approved if Keith got involved with motorcycles or flat track racing in any form. Not that the writers of the show weren't aware of the sport or could have added a bike trailer to the back of the bus. Just that the networks didn't see that type of thing as palatable for consumption by the general public. Too adventurous for those days: had to consider the heart-rate of John Q. Public.
    Might have really spiked the ratings if Keith had to race that afternoon and then make it just in the nick of time to appear on stage for the "C'Mon-Get-Happy" opener. And what if he sprained his wrist in a race? Would he be able to play the guitar or hold a microphone?? Far too much for the general audience of that period to handle comfortably/safely.
    No. No. No. Flat Trackers and Bubble Gum Pop just don't go together.
    Leave a comment:
  • clcorbin
    replied
    Originally posted by randy
    Clint,
    Get yourself a kickstart lever off an XS850 and you'll never have to split the cases. Well, never IS a long time
    I assume the XS860 lever folds? I have the original "emergency" level and have had to use it on a couple of occasions as well. I'm just hoping I get another 21 years out of this starter clutch then I KNOW I won't have to worry about it!
    Leave a comment:
  • randy
    replied
    Clint,
    Leave a comment:
  • clcorbin
    replied
    Originally posted by trbig
    Yeah, cold thick oil will cause it, less cranking amps from a cold or weak battery also. I wouldn't worry about it unless you have to hit the button half a dozen times every time you try to start it. To get to the starter clutch to rebuild.. you have to pull the motor and split the cases.
    My starter has been doing that for about 21 years that I know of. Because you DO have to split the case to repair it is the reason it is STILL doing the spin dance! When it finally dies, THEN I'll fix it.
    Kind of like the backlash in the diff on my pickup. It has had a TON of lash since I have owned this pickup (15 years or so on a 1981 Ford F100). I just KNEW that the ring and pinion on had a short time to live because of how bad the lash was. 15 years later, I am STILL waiting on it to die.
    Leave a comment:
    replied
    Leave a comment:
  • draketrumpet
    replied
    Bob, the starters on these are totally different creature than a boat or car. There's no bendix to kick forward like the other starters do. The starter on these are always engaged with the gear, it's the starter clutch.. basically 3 rollers at an angle that pinch against the shaft in one direction that has problems sometimes.
    Am I to presume, though, that the advice Bob gives is still sound: if it doesn't do it often, no big deal?
    Also, would a weak battery still cause it to not engage at times?
    Thanks.
    Leave a comment:
    replied
    Leave a comment:
  • XJOK2PLAY
    replied
    Originally posted by draketrumpet
    So, the last couple times I've started my bike, I hit the starter, and it sounds like the starter just spins without turning the engine over. I immediately let go and let it sit for 10-20 seconds, try again, and presto, starts right up...or at least as right up as it usually has in the cold.
    I'm a little new, so I'm not as familiar with all the mechanics that are going on underneath, but is this something I should be ripping the starter off to check in to? If so, what might be the problem?
    Thanks again.
    Mine does this occaisionally, too. It has to do w/ the starter drive not ejecting out into the driven gear. Sometimes, it's because the spring gets weak, sometimes it's because the shaft can get kinda cruddy and the drive gets sticky, sometimes happens if the starter doesn't spin w/ enough torque to throw the drive out as it spins up, (low battery,) and sometimes... it's just the nature of the beast. (Design.)
    Case in point... I've got a Champion Bass boat w/ a 175 hp Mercury Black Max outboard. The starter does the same thing sometimes, and is annoying when it does it. So... thinking I had a bad starter drive, I spent $40 & replaced it. Guess what? Yep... does the same exact thing. Sometimes design also plays a role in it as well. My starter, itself, is relatively new... including the battery.
    In this case, the starter is on the engine in a vertical position, and the drive must also fight gravity. Great for release, but not for engagement.
    On our bikes, they're on their side, which you'd think that would be better.
    I do know they're a pain to take off!
    You probably could replace w/ a complete new starter & drive, & find that sometimes it will continue to do the same thing. I would only worry about it if it gets REALLY bad... (like doing it all the time and not engaging.)
    It could have a drive that's getting a weak spring or crudded up shaft, and removal / cleaning / drive replacement might help. But if it's happening only on occaision, I think a lot of these 30 year old bikes do it. Mine does. Annoying when it does it, but doesn't bother me enough yet to start tearing it apart.
    HTH's.
    Bob
    Leave a comment:
    replied
    Tod, in my thread, spinning the engine was NOT to seat the rings, but to get oil through the engine. I think WickedGood is trying to say the same thing.
    Just my own observation after almost a cup of coffee.
    Leave a comment:
    replied
    And about seating the rings.. there's a recent thread on engine break ins that should be read. To think that simply rotating and engine and using the spring tension the rings have against the cylinders is going to seat anything... wrong. To assume that this few pounds of spring tension against the cylinder walls is going to hold back probably several thousand PSI in the combustion chamber... again, wrong. It's the combustion gasses forcing the rings against the cylinders. You can spin the motor until the cows come home with the plugs out, but you aren't going to seat the rings without the combustion pressures forcing those rings against the honed cylinders.
    Leave a comment:
    replied
    YOur truck battery or a Boat battery will work fine. DO NOT have it connected to the trucks alternator.
    LMAO.. Go back and read a bit. All of that has already been talked about. That's an old wive's tale that just won't die. It's kinda like replacing a 100 watt lightbulb with a 25 watt bulb, and people telling you it's going to blow that 25 watt bulb because the house is CAPABLE of operating the 100 watt. Just because you have your coffee pot on a 30 amp circuit... it doesn't mean your coffee pot is going to get 30 amps sent to it... UNLESS there's a short somewhere.. which is in the warnings about shorted battery cells.
    Leave a comment:
  • Guest
    Guest replied
    Spin the engine to seat the rings.
    Pull out all 4 Spart Plugs, Put some Marvel Mystery oil in the cylinders and turn over the bike for about 10 revolutions. Stop let it rest a few mins and continue that cycle for about 100 turns.
    Leave a comment:
  • draketrumpet
    replied
    Related possible problem
    Thanks again.
    Leave a comment:
    replied
    I don't know, did you ever see that ladies legs! (as in Bird Legs)
    Leave a comment:
