Will a low battry keep an XS11 from starting?
    replied
    Originally posted by oseaghdha
    If the bike battery has an internal short, it won't let enough juice through to the starter, like Ray sez.
    If it has a internal short, it won't read 12v; it will read less or more likely just be dead. If it has a partial internal open or is sulphated, it can still read 12v but won't deliver enough amps.
    '78E original owner
    Leave a comment:
  • clcorbin
    replied
    Originally posted by joceiphus
    If you have the kick lever. It wouldn't hurt to slowly kick the engine over a few times to spread the oil around.
    Also, if you do kick it over, the ignition system now has a LOT more voltage at it's disposal (no super high draw from starter pulling it down) so it will be able to start the bike much easier than if you are using the electric starter. I've been in situations in the past where I needed a new battery and I couldn't get it to fire off with the starter even though it WOULD turn the bike over at a fairly decent clip.
    But in doing that, it pulled the battery down low enough that the ignition system couldn't fire the plugs. A quick stab at the kick starter fired it right up even though I was turning the engine over SLOWER than the starter could, but the ignition had enough voltage to fire the plugs.
    Leave a comment:
  • joceiphus
    replied
    Leave a comment:
  • fabricgator
    replied
    When you jumped the battery from the caged vehicle, did you connect the ground jumper wire to the engine block? Wouldn't that give your starter the power of the truck battery regardless?
    Leave a comment:
  • 79XS11F
    replied
    Originally posted by Mathh
    Just a thought...have you checked the earth cable and its connections (free of paint) between engine and frame, they can corrode to the point of no connection. your engine will never start with this cable not intact..
    That's a good point Mathh. There is a short ground lead between the rear of the engine and the frame. It is often over looked during an engine re & re by POs. Perhaps it is missing. Good ground is very important for systems that use the frame as the ground part of the wiring.
    Rob
    Leave a comment:
  • 1st bike
    replied
    just my .02 cents....i went through a lot of checking and leg work (while my battery charged for seriously 2 days) and then bought a new battery....fired right up, no problems. after i let the battery charge fully on a trickle charger the old battery fired the bike too! now i have two batteries so while one sits and drains in the bike, the other is all set in the cabinet. let that battery charge for a LONG time, and hopefully you will be ready to ride. nice paint, btw.
    Leave a comment:
  • Mathh
    replied
    Leave a comment:
  • 79XS11F
    replied
    Your batteries ability to state your bike has more to do with amperage then voltage. Even a near useless battery will show 12 volts. It's the amperage that does the work. This is why batteries are rated in amp hours, or cranking amps. In any case if the engine will not fire with a jump from your truck something else is at play here. Your bike engine should turn over rather quickly with a jump from your truck.
    So, if even while jumped with the truck the engine is not turning over quickly your starter / starting system may need to be looked at.
    If it's turning over enough and still not firing, pull all the plugs and hook them up to the leads and lay them on the head. Turn it over and see if you have good blue spark at each plug and also note if the engine will now spin quickly with the plugs out. If still turning over slowly then you know for sure that the starter and or starting system need work. Back to firing, if you have a weak spark you may want to use high output coils that have a bigger gap and larger / hotter spark. Some plugs will not spark when under the added pressure of the increased compression ratio.
    If all ignition system appears good to go, then your needing to look at the fuel supply. Did you smell fuel when you pulled the plugs? Were the plugs wet with fuel?
    Rob
    Leave a comment:
  • oseaghdha
    replied
    I find it very odd that even with a battery that's putting out over 12v and a jump, it still wouldn't spin good. How about connections? Is your battery ground connected to clean metal? I see you painted your engine cases; if there's paint where any electrical joint is, that can be the problem. Same goes for the starter; if you had the starter off for repainting, did you remove the paint where the starter bolts to the cases?
    Could be a bad starter or solenoid too....
    '78E original owner
    BTDT.
    Leave a comment:
  • Mashermoto
    replied
    Great advise guys...you gave me plenty of work to do today
    Just as an update. I let the battery charge on a cheap bulk charger set at 2 amps over night and this morning I'm reading 14.37 volts. So that's a good thing
    I pulled the negative cable off (should have last night when I started the charging) and will check this afternoon to see how much drop in voltage I get. I should lose some as the battery cools down from the charge. Hopefully it won’t go below 13 volts.
    There is a very good potential that I have a bad starter, cable connection or solenoid issue. When you get a 30 year old bike in a box and then paint all those parts...only the shadow knows
    After church this morning, lunch with the family and take the kids to visit grandma and grandpa (in their mid-80's now), I'll put on my greasy duds, head out to the Man Cave and go through that V=IR and P=IV drill Larry posted
    I'll be baaaaaak
    Leave a comment:
  • MindWebs
    replied
    charging... regulator..... amps.... volts......
    Blah blah blah...
    12V to 12V, positive to positve negitive to negitive.
    if the bikes electrical couldn't handle a jump start my bike would be
    in ashes rate now.
    i've jumped many bikes and all is well.
    just DON'T reverse polarity when jumping, That WILL nuke electronics!!!!
    (drunk buddy jumped his beemer, it fryed the computer, i laughed...)
    Leave a comment:
    replied
    Originally posted by skippy344
    ...Things will catch fire because there are no isolating mechanisms to reduce the charging current.
    Uh, the 'isolating mechanism' is called a voltage regulator....
    '78E original owner
    Leave a comment:
    replied
    Failure to Launch??
    Mashermoto,
    Gawd!! Doesn't it suck to get this close to the sound and fury yet: DENIED!!
    Mechanical:
    Ok. Please consider that the newly rebuilt engine has yet to have that necessary oil/fluid in the cylinders and may indeed be a little tight. You don't have to guess about this. By pulling the spark plugs out and turning the engine from the timing plate bolt (Clockwise...) you can feel if it's tight. If it is then I'd say that squirting some marvel Mystery oil (or anything you have handy) into the open holes and then turning the engine over by hand a few times might gain some "ease of motion". Too much mechanical resistance can cause the starter motor to use more amperage, get hotter, and turn the engine over slowly.
    BTW: never keep cranking over a few seconds at a time. My rule is about 5 seconds cranking time to 30 seconds rest. These starters do not have any airflow/venting to cool them down after they get used.
    Electrical:
    Not gonna get into the car battery vs motorcycle battery/charging system debate on the grounds that I may incriminate myself.
    You have a multimeter there on the bike and it can lead you to where the problems may be.
    1. Place the meter across the terminals of the battery and read the voltage. Hopefully you're doing this in the morning and the battery is fully charged: 12.5 or 12.6 volts DC. Then try to start the bike while looking at the voltage readings.
    1a. If the voltage goes down past 9.6 DC Volts while you're cranking then the battery is no good OR the starter is drawing way too much current and pulling the battery down. (If you connect the truck/jumper cables and it still drops down past 9.6 DC Volts then OMG do you have a starter with shorted windings: Fire Hazard!!) Fix: new battery or new starter,
    1b. If the voltage doesn't go down and stays at or near the original 12.5-6 DC volts then it is likely that there is a bad connection providing high resistance in the starting circuit which is limiting the amperage flow to the starter. The starter needs those amps to do it's job so if it isn't getting them it will not spin the engine over like it should. Fix: locate bad connection or possible bad starter solenoid.
    2. Place one end of the meter on the positive battery terminal and the other end on the starter cable lug. ( Have to remove a cover more than likely...). Now try to start the bike again while looking at the meter readings.
    2a. What you're doing is checking for a voltage drop from the positive battery terminal to the starter lug. There shouldn't BE any voltage drop between these two points if the wire is in good shape and the connections are good also. If you read any voltage drop at all then there's resistance/bad connection between these two points. Fix: clean connections.
    3. Keep the one end connected to the battery positive terminal and connect the other end to the starter side of the starter solenoid. Again try to crank while looking at the meter.
    3a. Your testing for a voltage drop/resistance in the starter solenoid itself. Again if you read any voltage when the meter is connected this way then the solenoid is a problem. Fix: New solenoid or disassemble the unit and try to clean the contacts. (Been done before..)
    4. Dude. You may just have bad brushes in your starter. Gotta pull it out of the bike and then disassemble it. I've done that before on lots of bikes but not on any of my XS's so I don't know if the brushes are available. If not then Andreas Weiss be the man to check with for a used one.
    General Electrical:
    Don't forget the "Engine-to-Frame" ground cable near the middle drive or the battery negative to frame either.
    Never...EVER connect 12 volts to a starter which isn't installed and therefore has no load to turn against. Starters are "SERIES" wound and that means that they'll spin up faster and faster (and FASTER!!) to the point where they'll self-destruct.
    Hope this helps...I went for a ride today and it just ain't right for you to not be breaking that motor in....
    Leave a comment:
  • skippy344
    replied
    Do what you want, but I still maintain that a 75 to 100 amp charging system when connected in parallel, to a 30 amp charging system is not a good practice. Things will catch fire because there are no isolating mechanisms to reduce the charging current.
    Minimally, you can explode the motorcycle battery pretty completely.
    Just because you can do something, doesn't mean you should.
    Two words, Battery Tender.
    Leave a comment:
    replied
    '78E original owner
    Leave a comment:
