Mikes XS coils
  • boediddly
    • Dec 2009
    • 50
    • columbus,oh
    Mikes XS coils
    Whats the difference between the black and the green Mikes xs coils ,and does anybody have the part numbers?
  • tinman905
    • Aug 2007
    • 946
    • Orangeville,Ontario ,Canada
    Green higher voltage output and more money ,almost double but well worth it if you are changing coils. The part number can be found if you go on mikesxs.com. Just have a look in the electrical parts.
    BDF Special
    • MrOzz
      • Aug 2008
      • 782
      • Massachusetts
      Green Coils: Dual Tower XS Performance High Output Ignition Coil 3.3 OHM
      Primary Resistance. 15K OHM Secondary Resistance. Capable of
      sustained 45KV output with 12.5v DC input. Capable of sustained
      75KV output with 14v DC input. Replaces stock factory Tci
      ignition coils on All 1980 & up models and works with Pamco
      ignitions (Non rephased engine types). Requires 7mm Dia. High
      tension spark plug wires (order separate) and 5K OHM spark
      plug caps.
      Part #17-6810
      Black Coils part# 17-6803
      Unsure of specs so I will not post. You can email mikes xs and I am sure they will let you know.
      1980 XS 1100SG
      Dyna 3 Ohm Hi Output Coils
      Pod Filters
      DynoJet Kit
      T.C.'s Fuse Block
      V-Max Auto CCT
      • dbeardslee
        • 4385
        • Maineville, OH
        boediddly - I've had them both. The black ones lasted me 7k miles and crapped out. The green ones are hotter, and they seem to be of a more robust design. Additionally, the green ones will be easier to install new wires in when the time comes as you don't have to remove the coils to change wires. On the black coils you have to remove the coils to rewire. The black ones also require you to disable your old coils by clipping the primary leads off for use on the mikes coils. The green ones come with their own leads, so you don't have to cut wires off the old coils. You could also make your own leads, which I would strongly recommend if you go the black route. Then graft new high tension wires into your old coils and you'll have a spare set, which could come in real handy if you have the same experience with the black ones that I did.
        On a different note, I see you're up in Columbus. You might stop by the SWOXS social group page and make your presence known.
        • Mr. Schweer
          • Dec 2008
          • 152
          • Clovis, Ca
          plug caps.
          Part #17-6810
          So will the green coils work on my '79 Special??
          '96 Kawasaki ZX11, bought February 5, 2015
          '79 Kawasaki LTD 1000, bought Oct 19,2010.....sold Sept 12, 2013
          '81 XS11 Special, bought May 6, 2010.....sold Oct 19,2010
          '79 XS 11 Special, bought July 3rd, 2008
          '78 XS11 Standard, bought July 2, 2009.....sold Aug 25, 2011
            Yes. They will work.
              Someone did say somewhere that the dyna coils were cheaper than mike xs.
                I believe Dyna coils are $130 per pair from Z1 Enterprises.
                  It might pay to check Ebay, as I've seen pairs of the Dyna coils there for $110, with free shipping IIRC....
                  • MrOzz
                    • Aug 2008
                    • 782
                    • Massachusetts
                    Yes the Dyna Coils are cheaper than the ones from Mikes XS. If you use the 3ohm coils make sure you remove the ballast resistor located on the left side under your tank.
                    1980 XS 1100SG
                    Pod Filters
                    DynoJet Kit
                    T.C.'s Fuse Block
                    V-Max Auto CCT
