Are these ok?
  • Rickrod3
    • Jun 2009
    • 721
    • Oakland, New Jersey
    Are these ok?
    A private space for your group's photos and videos. Share, react, and relive moments together. Available on iOS, Android, and desktop. Free for new sign-ups.
    I pulled the steering bearings apart and cleaned them.
    Bearings seem to rotate smooth freely.
    The races have these marks best described as stains from the needle bearings.
    If I run my finger around the race I cannot seem to detect any bumps.
    Both the top and bottom races have them.
    Marks are located at the 12 and 6 O'Clock positions.
    Are they reusable?
    TIA
    Rick
    650SF
    XS1100SG Project bike
    Discoloration
    I saw the same thing when I did my bearings: "Stains" but no real obstacle for the bearings to roll into.
    I regreased, installed, and adjusted the headset: no glitches or rough spots afterwards. Turned real nice as far as I was concerned.
    My vote is to go ahead and reinstall what you've got.
    • Rickrod3
      • Jun 2009
      • 721
      That sounds good
      I re greased, installed, and adjusted the headset: no glitches or rough spots after wards. Turned real nice as far as I was concerned.
      They were dry so it was a good that I took them apart.
      I'm thinking they may have been Little loose to make those marks @ 12 and 6 on take off and stopping.
      I put the top bearing back in the race and it spun nicely.
      Rick
      650SF
        • 3193
        Considering how much work it is to get far enough to look at those bearings, I would replace them. I can not see much in the pics but if there are any marks at all on them, replace them. They are not that expensive. My 2 cents
          If the races are smooth, you should be ok. +2
          • 79XS11F
            • 3563
            • Ottawa, Ont. Canada
            If you already have them out I would drop in new ones but if you want to reuse the ones you have rotate the race 1/4 turn so the movement of the bearings is at a new spot on the race.
            Rob
            KEEP THE RUBBER SIDE DOWN
            1978 XS1100E Modified
            1978 XS500E
            1979 XS1100F Restored
            1981 Suzuki GS1100
            1983 Suzuki GS750S Katana
            1983 Honda CB900 Custom
              I'll agree with Larry and Phil; clean and repack the bearings and put 'em back.
              As long as you don't get any rust in these, they'll outlast the bike.
              '78E original owner
