The Epic continues...Opinions on the oil pump?
  • randy
    • Dec 2003
    • 4521
    As many of you have read, what began as a starter clutch fix has morphed into a complete going-through. I've sorted out the bearing conundrum, thanks for all the input everyone. My rebuild epic continues...and I really don't like the looks of this...
    Opinions?
  • petejw
    • 2269
    • sydney australia
    hey randy,
    bit hard to tell by the pic but if those score marks are deep enough and allow the oil to bypass the pump,
    then i think you might need to replace it.
    if there not too deep, you might be able to rub it back a bit.
    pete
    new owner of
    08 gen2 hayabusa
    former owner
    1981 xs1100 RH (aus) (5N5)
    zrx carbs
    18mm float height
    145 main jets
    38 pilots
    • randy
      • Dec 2003
      • 4521
      That was my opinion, too, Pete. I COULD reface the cover and the outer rotor, but can't do anything with the inner rotor nor the inner housing. It has similar gouges. The clearance between the inner / outer rotor is OK, though.
      • petejw
        • 2269
        • sydney australia
        it was the score marks on the inner and outer rotor
        that would have me worried, i could see where oil could
        leak past. being that youve replaced the bearings and all,
        i wouldnt take the risk in using it.
        how did u go with the bearings,
        which ones did u end up using?
        i wonder what you picked up to cause that,
        did u find anything in the oil?
        pete
        new owner of
        08 gen2 hayabusa
        former owner
        zrx carbs
        18mm float height
        145 main jets
        38 pilots
        • red bandit
          • 950
          • central michigan
          Any idea what kind of oil pressure you used to have?
          79 SF parts bike.
          • petejw
            • 2269
            • sydney australia
            pete
            new owner of
            08 gen2 hayabusa
            former owner
            zrx carbs
            18mm float height
            145 main jets
            38 pilots
              Randy,
              Ya know, I've never actually taken one of the oil pumps apart. I could take a look and see if they all have that scoring. If they don't, I could send you one of you need it. I've got one or two.. or ten laying around here.
              • andreashweiss
                • 951
                • 180 mile northwest of Spokane,WA
                I have taken lots of those oil pumps apart and have to agree that thing should be scrapped out, looks used up, never seen one worn out like that, Yamaha built a good solid oil pump, it has had it, do not use it, find another one, sorry I do not have any , thanx andreas
                  Andreas.. that's surprising! I figured that would be one of those things you'd have 50 of.. lol.
