Which Came first .... Drive Shaft Question
  • res1uqtp
    • May 2009
    • 84
    • East Central IL
    Ok all this is my first complete rebuild on a bike with a drive shaft. So I've got this beautiful frame in my basement and I'm ready to start reassembling and it dawns on me that before I put together a rolling chassis I should probably ask this question......
    Do I need to mount the engine first before I assemble the rear or will I be able finesse it in and mate it to the drive assembly after the rear is already assembled??????
    To be honest every rebuild I've done to this point have all been chain driven ... never came up before. Thanks in advance guys.
    My Stable:
    2006 Triumph Bonneville Black
    1979 Yamaha XS11 Special (2 of them)
    1982 Yamaha XS400 Heritage Special
    1981 Suzuki GS550 E
    1976 Honda CB550F Supersport
  • 79XS11F
    • 3563
    • Ottawa, Ont. Canada
    The engine can go in after the whole rolling chassis is complete.
    Rob
    KEEP THE RUBBER SIDE DOWN
    1978 XS1100E Modified
    1978 XS500E
    1979 XS1100F Restored
    1981 Suzuki GS1100
    1983 Suzuki GS750S Katana
    1983 Honda CB900 Custom
      It can be done either way. It's easier if the engine goes in first, then the driveshaft/swingarm. JMHO
      • TADracer
        • 1417
        • Kenner, Louisiana USA
        third option
        There is a third option. Make up the rolling chassis then install the engine without the middle drive. Gives some wiggle room at the drive shaft flange while fitting the engine in the frame. Then install the middle drive.
        I have done all 3 ways and find no one way much better than the other, especially if you have a helper or two.
        Mike Giroir
        79 XS-1100 Special
        • Ivan
          • Jul 2008
          • 2524
          • Hutchinson KS
          Well, the hardest way would be if you pulled the driveshaft out of the front U joint yoke. That is a real pain to get back together. Any other way should be ok.
          Ich habe dich nicht gefragt.
