...And the bill keeps growing...
  • Rev.Rick
    • Dec 2009
    • 129
    • Loganville Georgia
    Well, everytime I think I'm about ready to button things up and get ready to ride, I find something else. While waiting for my carbtune to arrive, I decided to do a little polishing. Some past owner painted the valve cover and the crankcase covers with silver paint? I'm not sure what kind of paint it is but even Aircraft paint stripper has little effect on it (could be powder coating, not sure). Anyway I did both the covers over the ignition and the stator. Next In line is the valve cover. Since I had it off I checked the valve clearance. Not good! They are all too tight. The #1 and #4 intake valves are so tight I can't get a feeler gauge between them. the #2 and #3 are like .05 and .08. The exhaust valves ranged between .20 (#3) and .15. I don't have a valve tool so thats more $ and then get the correct shims. I certain wish I had of found this out before I bought the carbtune. Anyway Does anyone know a good place to get the shim bucket tool (cheap) and the shims (cheap). I know I sound like a bird, but wow, by the time I get to ride this thing for the 2nd time I may be divorced
    Rev.Rick
    What I ride now: 1980 XS1100 Special
    What I used to Ride: 1980 XS850, 1984 Honda V65 Sabre, 1974 Honda CB750 ss, Yamaha YZ 480 (bored YZ400), Kawasaki 500 triple
    Amazing Grace, how sweet the sound that saved a wretch like me! John Newton (1725-1807)
  • Ivan
    • Jul 2008
    • 2524
    • Hutchinson KS
    Stickies have a post about the valve shim library. The tool isn't necessary, you can loosen the cam caps to get the clearance to replace the shims.
    Chances are you will just be moving a few of them to different places, and only actually need a couple different ones.
    As long as you keep everything lined up, you can loosen the sprockets from the cams, which gives enough room to loosen the caps, and even pull the cams if you want. Just take your time and keep everything in line. Make sure its all lined up before tightening down the cams.
    Ich habe dich nicht gefragt.
    • Rev.Rick
      • Dec 2009
      • 129
      Thanks Ivan. I had read through some of the past threads about loosening the cams. I will try that. the biggest reason I posted this was for the shims . The past post I read looked like older ones so I wasn't sure about the availability of the shims. Thanks again, Rick
      Rev.Rick
        • 8937
        In case the valve shim library doesn't have the sizes you need, this supplier is very reasonable...
          If you have any bike shops around you, call and ask them if they have any. Some will trade with you without cost. Mine is $5 each to walk in and get what I need. Take a caliper with you though. Some bikes made a 29.5mm shim as opposed to our 29mm. You can't tell the difference by looking or even having them side by side. They just won't fit in the bucket seat.
            With that many valves needing to be adjusted, I would go the route of loosening the cams over the tool.
            As to shims, I found a local bike shop that has a fll assortment and will sell me all I need for $3 a shim IIRC give or take a buck a shim.
            • dbeardslee
              • 4385
              • Maineville, OH
              That can be a problem when it comes to ordering shims. You really need to be able to get a gauge in there to determine the shims you need. You might be able to move some of the other shims to these locations (if you've got thinner ones that are currently installed on other valves) to open the gap enough to get a gauge in. JAT
              I'm with the rest on not needing the valve tool. I borrowed one from a friend the last time I adjusted valves, and was seriously considering buying it from him - so I could take it out in the driveway and beat the snot out of it with a three pound sledge - not a great tool.
                Hi Guys,
                this is embarrassing. The XS11 is my very first shim & bucket motor; all the others that weren't 2-strokes have had sensible wrench-adjustable tappets. I was hoping that at my age any valve clearance issues my XS11 developed would be the problem of whoever inherited the machine.
                But in case I have to deal with it myself, I need to know.
                Do the clearances get bigger as the valve train wears so that they clatter louder as the miles go by?
                Or do the clearances close up so I won't know if the valves are about to burn out or if I am losing more of my hearing?
                  • 8937
                  Fred, the clearances close up over time. The valve gets hammered into the seat reducing clearance. When in doubt, check 'em out.
                  • cywelchjr
                    XS-XJ Super Guru(Deceased)
                    • 4450
                    • Sacramento, CA
                    Hi Guys,
                    They wear closer. I guess it's the lack of moving parts, but according to our roommate who is going to UTI to become a mechanic, this is common to shim and bucket valve systems.
                    • randy
                      • Dec 2003
                      • 4521
                      If the library comes up short, I have a few dozen assorted shims. Let me know what you need and I'll check stock.
                      • petejw
                        • 2269
                        • sydney australia
                        Ive just done adj mine again,
                        with regards with the shims that are tight,
                        i dropped 2 sizes on the shim that was fitted that is if the shim was 270
                        i put a 260, this will get you close, if not will allow enough of a gap
                        to measure.
                        Ive never used the tool,
                        i do one cam at a time, remove all the cam nuts, do NOT loosen the cam
                        chain there is no need, and prevents any chance of slipping.
                        the cam will rise enough to be able to remove the shims, you can also
                        rotate the crankshaft slowly and carefully, but do NOT rotate the engine backwards to allign the cam to get to the next shim, when the shims are replaced
                        torque back up and do the next cam, then while the cover is off carefully
                        adjust the tensioner per specs.
                        btw once you have adj all the valves correctly,
                        you wont believe the difference in power and performance.
                        i had 2 tight intake valves on mine.
                        pete
                        new owner of
                        08 gen2 hayabusa
                        former owner
                        1981 xs1100 RH (aus) (5N5)
                        zrx carbs
                        18mm float height
                        145 main jets
                        38 pilots
                        • petejw
                          • 2269
                          • sydney australia
                          Hi Fred,
                          The valves do close after time,
                          the manual states for better performance
                          to set the valves with the smaller clearances.
                          IMO if the valves have had no work done to them, that is
                          valve lap/grind id go for the smaller clearances, if the
                          valves have had work id go the larger clearances.
                          pete
                          new owner of
                          08 gen2 hayabusa
                          former owner
                          zrx carbs
                          18mm float height
                          145 main jets
                          38 pilots
                          • Rev.Rick
                            • Dec 2009
                            • 129
                            Hey Pete, thats the exact method I used last night to start adjusting mine. I loosened all the cam caps and used a screwdriver to gently lift up on the cam enough to move the shims around until I got the clearances needed. I got one of the ones that was too tight corrected by installing one that was .10 smaller. I was able to move around the shims so that I got 3 of the exhaust valves and 1 of the intake valves within specs. Randy is sending me a shim that will correct the one exhaust valve I lack and I'm waiting to hear about the other shims I need. Rick
                            Rev.Rick
                            • dbeardslee
                              • 4385
                              • Maineville, OH
                              When I do mine, I don't remove the nuts - just loosen them. I leave them a little tighter on one side so the cam rises at an angle when it pops loose. You'll still have enough room to get at the shims, but less stuff to fall down into the cam chain tunnel that way. JAT
