How to: Trim on Vetter
    • 3189
    Ok how does one go about getting the trim strip off of a vetter fairing and lowers? I want to paint mine and need to get them off to properly sand and paint them. Is there a trick to it or a simple route to go? I just don't want to wreck what is there in case I have any problems finding new stuff. Also any ideas about prepping the pebbly part of the lowers? Seems like it may be tough to sand...lol. I am also looking for a left side cover for a 81 MNS if anyone has one in good shape.
  • cywelchjr
    XS-XJ Super Guru(Deceased)
    • 4450
    • Sacramento, CA
    From craigvetter.com:
    What is the secret to getting the old edging off the fairing?
    I pry off the corner where it is close to the tank with a screw driver. Then grab the loose end with pliers and yank hard, 90 degrees from the fairing. It lets go.
    • tinman905
      • Aug 2007
      • 946
      • Orangeville,Ontario ,Canada
      cover
      There is a 81 MNS cover and bits for sale on e-bay now 230432674396 is the item number.
      BDF Special
      • tinman905
        • Aug 2007
        • 946
        trim
        You can buy new trim but it is very expensive. If your trim is still in good condition leave it on and tape it off before painting.The trim can cost almost as much as the paint job.
        BDF Special
          You don't do ANYTHING to the "pebbly" part. Never sand it, paint it or otherwise mess with it. It is textured ABS, and is meant to remain black.
          I think there are quite a few of us looking for that part. There is one on ebay, but they want a fortune for it. Every once in a while, a used one pops up, but they usually sell for $75-$100.
          I don't know where you are getting your trim, but that stuff is relatively cheap. At craigvetter.com, it's $62 for enough to replace the trim on just the fairing, and $82.50 for enough to do the lowers as well. The kit comes with the fancy Hotcha glue.
          • pete_s
            • 104
            • NoBranford CT
            Don't say you can't I painted my Vetter years ago with standard epoxy primer and House of Colors 2 part urethane, the rough inner/driver side came out good too!
            1967 Bultaco Metralla 250
            RD125
            1973 CT3 175
            78 XS1100E
            80 XS850SG
            • cywelchjr
              • 4450
              • Sacramento, CA
              I don't think I would bother with the rough driver/inner side, but I'm going to be painting mine this spring. I'll be using rattle can paint (duplicolor three stage color changing paint) that I will then cover with a few coats of 2 part clear as recommended by duplicolor. It's a good looking paint and I've been wanting to do the bike with it since I got it. I'll be doing the fairing, tank, side covers, saddle bag lids and the trunk sides and lid. I'll try to post pics showing how it looks when I get it done, or barring unforeseen problems those on Loho's ride this summer will be able to see it in person.
              I'm not going to replace the trim either, just going to mask it off.
              • slow mo
                • 858
                • ontario canada
                don,t waste your money
                I don't know where you are getting your trim, but that stuff is relatively cheap. At craigvetter.com, it's $62 for enough to replace the trim on just the fairing, and $82.50 for enough to do the lowers as well. The kit comes with the fancy Hotcha glue.[/QUOTE]
                i agree with tinman ;;don't waste your money ,tape the trim and paint the part!!
                The Belfast Express {1980 xs11oo special/TC fuse box/mikes xs pods/bad boy horn!/mikes green coils/mac 4 into 2 exhaust/ standard bars/vetter fairing c/w ipod CD iphone am/fm radio/tkat fork brace ,,,tuned by tinman
                moemcnally@hotmail.com
                i AM THE KING OF NOTHING
                the people here are great , doesn't matter about the bike really/hamjam ////
                • Crazcnuk
                  • 2980
                  • Hinton, AB, Canada
                  Derwat painted his, inside and out. He removed the trim and rounded the edges to make them smooth and not need the trim.
                  He also filled in the body lines to make it look 'different' from normal Vetters.
                  he found a lot of unknown cracks when he did this.
                  '05 ST1300
