Three symptoms
  • Filter
  • Three symptoms
    Three symptoms
    #i...i've got a ticking noise in the motor since we adjusted the valves...did we get one wrong?
    #2....i was running rich..i put the proper pilot jets in (42.5) and now i'm lean.........how many turns out on the adj. Screws before i should go to 45's.....?
    #3...when i pull the vacuumn cap for carb #4 or #3 or #2 the idle goes down...but #1...no real change in idle speed.....that means???
    DENNIS
    1981 MNS..1980 CARBS , STOCK AIR BOX, FIVE 1/2" HOLES IN BACK OF MUFFLERS (SINCE COVERED UP WITH A BIG WASHER)
    1983 HONDA 350R
    1972 YAMAHA 250 MX
    196? MONTESA 250 ENDURO STRIPPED DOWN
    1967 BENEILI 125 ENDURO (NOWHERE NEAR BIG ENOUGH)
  • #2
    I think I can help with #1. Ticking valves is a good thing. It lets you know there is valve clearance. It's when there is complete silence that can be a bad thing (means the valves are set too tight). As long as valve clearance is within spec, don't worry about ticking.
    Someone else will have to help with numbers 2 and 3 since I haven't dug into my carbs yet.
    1980 XS1100 Standard "Touring"
    Fairing, Trunk, and Bags
    850 FD
    Fork Brace
    Progressive Front Springs
    Engine Guards w/Foot Pegs
    Oil Cooler
    Throttle Lock
    Uni Air Filter in Airbox
    2009 Suzuki Bandit 1250S ABS
    • #3
      As stated, the top end of an XS11 is somewhat noisy. Sounds like you opened up the clearances to where they should be and are jus tnow hearing it run as it should. Check engine oil just to be sure though. If you have to little, fill it up, if it looks really high, check for gas in the oil. If you want to be really sure your getting oil to the head and valves, loosen the banjo bolt on that oil tube running up to the back of the head between 2 and 3 intake boots. Just bump the engine over or barely start it and you should see oil pump out of it.
      Typically, if you turn the screw out 5 or more turns it is time to change jets.
      Are you certain no 1 is running at idle? Spray water on the headers and see if no 1 is just as hot as the rest.
