Front wheel bearing removal
  • Rickrod3
    • Jun 2009
    • 721
    • Oakland, New Jersey
    Saw a thread by Big Dick but I couldn't understand what Skids was explaining. Sorry so I have to ask it again.
    Have both seals off and the pieces for the speedo gear out.
    And have tried to drive the bearings out.
    I'm afraid to hit too hard since I'm not sure which way are they supposed to come out?
    Does each bearing have to come out its respective side or can the both be driven out from one side?
    If so which one?
    I get a bad feeling when I'm pounding on something and not sure how something is suppose to happen.
    Tia
    Rick
    650SF
    XS1100SG Project bike
  • XS1100 Newbie
    • Jun 2009
    • 1106
    • Battle Ground, Washington
    You first need to take a prybar of some sort and pry the right side of the spacer in side the hub over. The side opposite the speedo will move off to the side. This allows you to get to the race of the bearing to drive it out. The remove the spacer, and drive out the other side.
    1980 XS1100LG Midnight
    1991 Honda CBR1000F Hurricane
    A cold beer and another one!
    • blue giant
      • Aug 2007
      • 880
      • Ontario, Canada
      XS1100 Newbie has it right. Place the wheel on a solid block of wood so you don't damage the rim. It will take a good bang to pop them out. If you can use a bit of heat around the outer portion of the rim where the bearing sits it might help. I remember thinking the same thing, something is gonna break but be persistant! An overnight soak with penetrating oil between the bearing and rim might help as well.
      Paul
      1983 XJ1100 Maxim
      1979 XS1100 Standard
      1980 XS1100 Special
      • Rickrod3
        • Jun 2009
        • 721
        spacer wiggles
        Spacer wiggles but won't slide over.
        I'm starting to feel pathetic.
        Rick
        650SF
          • 7830
          Use a THIN, LONG punch on it. Once you have one side moving just a little, the spacer will be out of the way. You CAN use the punch on the center of the bearing if you are going to replace it. If you are NOT going to replace the bearing, DO NOT REMOVE IT.
          • Rickrod3
            • Jun 2009
            • 721
            Thanks will give it try in the AM.
            Maybe I'll see it in a different light
            Rick
            650SF
            • randy
              • Dec 2003
              • 4521
              Alternate your hits either side so as not to cock the bearing in the bore or it will get stuck DAMHIK
              • Rickrod3
                • Jun 2009
                • 721
                Eating the elephant
                Thanks to you guys I took another bite of the elephant.
                The manual is a little misleading.
                It gave me the impression that I would be able to remove them clean and repack them.
                Oh well new front wheel bearings on a bike with 34k that sat for 26 years really doesn't take much to Justify.
                Especially since their cost isn't bank breaking.
                I read some of you have gotten them locally.
                Does anyone have a part # the auto parts might be able to cross. I'm thinking the Yamaha #'s won't mean anything.
                Rick
                650SF
                • randy
                  • Dec 2003
                  • 4521
                  The number is on the bearing they are common numbers any parts store can cross-ref them
                  • Rickrod3
                    • Jun 2009
                    • 721
                    Thanks Randy
                    BTW nice site
                    Rick
                    650SF
                      • 2101
                      Repack...
                      them by carefully ,with a small drill bit, drill a hole in the seal of the bearing. Better if You use a hand drill so you can feel what Your doing and don't go too deep. Then use a needle tip on a grease gun and lube away! Also spin the wheel as You lube so grease is distributed evenly. HTH
                        The bearings I got were from a local bearing shop.. and yes they were quite common. I think I gave $5.50 a piece? One side of the bearings I had didn't have a dust shield.. just open bearings. Even if you have the shield on them, you can pack them well just forcing grease through the small crack between the shield and the outer race... but you can also drill the hole as mentioned.
                        If you have a grinder of some sort, take one of your old bearings and spin it slowly while grinding it evenly on the outside of the race until it slips easily in and out of the wheel hub. When you get the new bearing, set it in place in the hub, and use this old bearing... hitting it with a hammer to drive in the new bearing. Don't forget to install that spacer in the middle before putting on the second bearing..
                        • Rickrod3
                          • Jun 2009
                          • 721
                          Good Tip TR.
                          Using the old one as the tool to drive the new ones in.
                          I was going back in forth with my sockets must have tried the same ones a few times in disbelief that non of the fit quite right.
                          The old one is sure to be an exact fit.
                          Rick
                          650SF
                          • randy
                            • Dec 2003
                            • 4521
                            Rick,
                            Also helps to put the new bearings in the freezer overnight. Install them while still 'frozen ', they slip in real easy-like!
                              Maybe that's why I was having such a hard time getting mine OUT! I was attempting it while the temps outside had been below freezing all week, so botht he bearing and the wheel were frozen!
                              I'm concerned about Rickrod's statement about the bearings not being repackable. I gave up on mine and decided to come back to it later, but are you saying that I can't re-pack the stock bearings? Not that $11 for 2 new bearings is expensive, but the manual says I can do it for free. It looked like I could see the actual balls in the bearing once I took the dust shield off the outside. I figured that once I got them to come out, I could easily clean and repack them.
