Hey everyone. Being that I'm new to owning an XS110 Eleven Special,I'm still learning new things about it. I was wondering why the headlight only comes on after the bike is started and not just when the key is turned to the on position. Is this the way this bjke works or do I have a wiring problem?
Headlight
Jamie, don't feel too bad. I put an HID conversion kit in mine when I first got it and couldn't get it to light up. I knew the head light that was in it before worked so I put it back in and guess what, thats right it wouldn't come on either. I had the carbs off the bike soaking at the time so I couldn't crank it. I spent two frustrating hours tracing wires and testing connections. Finally I got on here whining and they were kind enough to tell me that the bike had to be running before the headlight would come on. At least you asked before you tore the wiring harness apartRev.Rick
What I ride now: 1980 XS1100 Special
What I used to Ride: 1980 XS850, 1984 Honda V65 Sabre, 1974 Honda CB750 ss, Yamaha YZ 480 (bored YZ400), Kawasaki 500 triple
Amazing Grace, how sweet the sound that saved a wretch like me! John Newton (1725-1807)
But wait! There's more!
Originally posted by Jamie Lowe View PostHey everyone. Being that I'm new to owning an XS110 Eleven Special, I'm still learning new things about it. I was wondering why the headlight only comes on after the bike is started and not just when the key is turned to the on position. Is this the way this bike works or do I have a wiring problem?
as posted, the headlight comes on when the alternator starts charging. But don't worry about being suddenly left in the dark if the alternator stops charging. Once the relay turns the headlight on it will stay on until the key is turned off. In a related feature, if one headlight filament fails the system automatically switches to the other and the white warning light in the console lights up.
Note that this system ain't perfect. If the high beam blows it switches to the low beam OK. If the low beam blows it switches to the high beam at a reduced Voltage which means there's just enough light for others to see you coming but nowhere near enough light for you to see where you are going. This is alleged to be a safety feature.Fred Hill, S'toon
