chrome polish techniques
  • dontlikeoc
    • Nov 2009
    • 173
    • Alhambra, CA
    I got the Mother's polishing cream. My question is about what cloth/sponge, etc. to use for the best result. Using the cream on an old sock didnt make much change...I am polishing side covers. Also, how long should I expect to spend for a decent result? (as long as to cause carpal tunnel?).
    dontlikeoc
    1981 XS1100 Special Edition
    Alhambra, CA
  • Ivan
    • Jul 2008
    • 2524
    • Hutchinson KS
    Mothers is really not abrasive enough to handle chrome, its best suited for softer metals like aluminum and brass.
    Turtle wax has a pretty good chrome polish, with just a bit more tooth to it than Mothers. On bare chrome it does pretty good.
    Ich habe dich nicht gefragt.
      If you are polishing your case covers (aluminum, not chrome), try tin foil. Works great. YMMV
      • mro
        • 4276
        • Hayward, California
        Polishing?
        This is a good read to get you started.
        mro
        Weird, all I been doing is use it to make hats...
        • 79XS11F
          • 3563
          • Ottawa, Ont. Canada
          Use English Custom Polish. I've never seen anything like it for cleaning and polishing alloy.
          Rob
          KEEP THE RUBBER SIDE DOWN
          1978 XS1100E Modified
          1978 XS500E
          1979 XS1100F Restored
          1981 Suzuki GS1100
          1983 Suzuki GS750S Katana
          1983 Honda CB900 Custom
            Tin foil and mothers works well. Also tin foil and coca-cola. It's definitely an old timers trick but is very effective. By all means I am not an expert, but I've got many compliments on how clean my bikes look, just by using these simple methods.
            • tw1980
              • Apr 2009
              • 662
              • Bend OR
              Boy it's a good thing I saw this before you listened to these other people.LOL Just kidding.Any of those techniques will work with enough effort.It depends on what kind of shape your side covers are in when you get started.If your aluminum covers are pitted or covered with clear coat.I would recommend you start with some 250 or 500 grit.Then move to 1000 after the big stuff is gone.After that use red stick rouge on a bench grinder with a cloth buffer wheel.Then finish with some mothers and a soft rag.They'll shine like chrome.Use the mothers to touch up every now and then.Good luck! Terry
              1980 special (Phyllis)
