My bike has been parked unregistered in the garage for a couple of months. Sad. The tire mysteriously went flat. I'm fixing that currently.
I put some gas in it to start it and let it run just because it was sitting for so long. I must have smoked up at least one block. The thing just pukes gobs of smoke when starting.
When I tried to zip the throttle up and down the bike would instantly die. It would not run unless it was on full choke. I found that if I held the throttle wide open it would run without choke.
While I had it running I removed the spark plug wire from number 4 and there was no difference in RPM or anything else. Same thing on number 3 cyl. Seems I'm not getting any fuel to those two carbs now.
On another note, I'm in the process of recoating a spare tank with Caswell Epoxy. As soon as it gets here I'll treat the rust and then coat it. The tank is already primered.
Anyone have suggestions for smoothing out the transition areas between bondo and the metal? Bondo always seems to leave a seam.....
I would be interested in trying the acid treatment on the tank this time around instead of just lacquer thinner - what's acid recipe?
I had keys made by the local locksmith for $20. Much better than fussing with the local dealer who refuses to even try to get me a key....
Ben
Ben
I clamped the key and the blank together and a little file here and a little file there - a key. It actually worked on the first try.
