Carb id
  • MNS494
    • Jan 2010
    • 32
    • BOISE, ID
    Carb id
    I'm tfrying to see if the carbs are stock on my 81 mns...on the top side of the carb, partially under the choke lever are these numbers
    3h5 oo
    b065
    mean anything?
    DENNIS
    1981 MNS..1980 CARBS , STOCK AIR BOX, FIVE 1/2" HOLES IN BACK OF MUFFLERS (SINCE COVERED UP WITH A BIG WASHER)
    1983 HONDA 350R
    1972 YAMAHA 250 MX
    196? MONTESA 250 ENDURO STRIPPED DOWN
    1967 BENEILI 125 ENDURO (NOWHERE NEAR BIG ENOUGH)
  • CatatonicBug
    • 6117
    • Clinton, UT
    I'll check on mine when I get home. Are yours painted black? The bodies and bowls should be black, and the tops should all be gold. The '80 MNS had only the outer 2 (1 and 4) gold.
      • 8798
      Post a couple of pics, then someone should be able to ID them for you.
      • Crazcnuk
        • Aug 2006
        • 2980
        • Hinton, AB, Canada
        3H5 is the designation for 1980G (standard) models.
        However, we have seen many wierd combos.
        '05 ST1300
        • CatatonicBug
          • 6117
          • Clinton, UT
          Mine have no such numbers in that location. All I have is a big "MIC", then, under that is "Mikuni", then under that is "Kogyo". No numbers at all. As Craz said, it looks like those carbs may be from another bike.
          • Crazcnuk
            • Aug 2006
            • 2980
            Those numbers can be very hard to see. They are very faint, etched, kind of. There are no indents or raised parts of the number, more like a silk-screen.
            You have to get th light on them just right, sometimes, in order to see them.
            '05 ST1300
            • MNS494
              • Jan 2010
              • 32
              • BOISE, ID
              tTHE CRAZYCANUK IS RIGHT...I'VE FOUND OUT THEY'RE FROM AN 80 STANDARD...NOW I NEED TO FIND OUT HOW AN 80 STANDARD WAS JETTED.......HOPE THIS ISN'T THAT OLD 80'S --NEW 80'S THING........THANKS...I THINK I'M CLOSING IN ON A GOOD RUNNING BIKE......
              DENNIS
              1983 HONDA 350R
              1972 YAMAHA 250 MX
              • Crazcnuk
                • Aug 2006
                • 2980
                The 80G carbs were originally set up as:
                mainjet
                115 Outside carbs
                120 Inner carbs
                X-2 needle jet
                25 starter jet
                42.5 Pilot jet
                140 Air jet, main
                185 Air Jet, pilot
                Needle 51 Z7
                Float height .906 +/-.20in
                110 Outside carbs
                120 Inner carbs
                X-2 needle jet
                25 starter jet
                42.5 Pilot jet
                140 Air jet, main
                185 Air Jet, pilot
                Needle 5GL-16
                Float Height .12 +/- .04in
                The later service bulletins just say to use #110 mains on all 4 cylinders. So the only differences are the needle and the float height.
                '05 ST1300
                • MNS494
                  • Jan 2010
                  • 32
                  • BOISE, ID
                  Thank you , thank you, thank you.....i'll order the right needles this morning from my yamaha dealer and put it together when they get here........we put a wire guage on my pilot jets and they measured 55+.....so i've got 42.5's coming....don't know why those were in there.....thank you again craz...you've got one person thinking good thoughts about you...hope it brings you good luck...
                  DENNIS
                  1983 HONDA 350R
                  1972 YAMAHA 250 MX
                  • MNS494
                    • Jan 2010
                    • 32
                    • BOISE, ID
                    Nothing ever is easy....does anybody know, or tell me where to find, the yamaha part number for a jet needle 5 I Z 7 ?........ It would save me having to deal with the parts guy...
                    DENNIS
                    1983 HONDA 350R
                    1972 YAMAHA 250 MX
                      • 8798
                      Those needles aren't easy to find and ain't cheap. IIRC, you gotta buy a whole carb kit which includes them. What needles do you have now and why are you changing them?
                      • MNS494
                        • Jan 2010
                        • 32
                        • BOISE, ID
                        I found out my carbs are from an 80 standard and someone jetted it thinking they were stock....an 81 mns.....so everything is the same except the jet needle and the mains and the float height....soo............i 'm putting the float height at 23mm.....i think i can get away with the 110 mains all the way across cause boise is 2900 ft. Up...............right now the needles are 5 g l-16 's and i'd be happy if you think i could get away with those....i'll probably never get over 80 mph........
                        DENNIS
                        1983 HONDA 350R
                        1972 YAMAHA 250 MX
                          • 8798
                          There is no reason the ones you have won't work unless they are badly worn. Go with what you got. Make sure you run the rubber plugs over the pilot jet tunnels tho.
