That was my first thought!
Randy I have that bolt as well. Let me know!
Paul
Splitting the f*%$#@ng cases
Hi Clint,
I swear that little clutch is the component they build the entire engine around.
Starter just goes "whizzz" and the engine don't turn over?
I'm not saying that your starter clutch ain't fried but what fixed mine was a fully charged battery.Leave a comment:
Leave a comment:
If he doesn't come through for you Randy, I've got probably a half dozen sets.. lol. I have a couple on cardboard pushed through holes numbered for each bolt, so I can be sure to send the right one.
I can't believe those two broke though.. that's really weird. Both of those sit INSIDE the case.. or at least both are bathed in oil constantly, so there shouldn't have been corrosion. I've broken a few along the front of the cases before.. 11-17.. but never heard of the others. Are you sure it hadn't been apart and the bolts Lock-Tited maybe?
So are you going to drill and tap them?
TodLeave a comment:
Pretty sure I have some here, two sets if I am not mistaken. I have a set of cases that are split so all the bolts are loose in a bag. If ya get the measurements (to make sure I have the right bolts) I can send em to you. If you want or need the set I have just PM me your mailing address and I will get them sent.Leave a comment:
Well, looks like these cases haven't been apart in 30+years. Recently I began a tear-down to repair my fried starter clutch and wouldn't you know it, two lower case bolts snapped. The #1 and the #18.
#1 is available new, but not #18. Anyone got any spare case bolts lying around? The #1 is a main bearing saddle bolt (#13 in the fiche) and #18 is a 6mmX85 long (#16 in the fiche).
TIA,
Randy, the bolt snapper Guru.Tags: None
Leave a comment:
