Running lean
Hi,
I resynced the carbs with the correct airbox and took it for a test run. There was improvement but at around 150 Km/h in fith gear it does the same thing. The plugs on cylinders 2,3,4 burns white, with 3 almost glazing. Only cylinder one burns sandy brown.
With the the float levels all exactly the same I don't understand the coloring if only the float level determines the mixture at that speed. I set the level at 25.7 ('78 xs 11 specail) Is there anything else that can cause the bike to run lean or the plugs to color white?
I will really appreciate any suggestions.
Hi,
