Hi all,
I have been working this thing over since I can't find the necessary tire chains to ride it. Some of you have seen some of these changes, and it has changed alot since the picture taken for the #4 calendar (November). I took some neat pics tonight and thought I would share them:
I am now thinking about clip ons. I would like to push the forks through the top tree to give a little lower front profile. I decided against pursuing a cafe seat for now. I think the XS looks a little too short front to back to remove the rear fender. The stock fender with that light and mount makes it look a little more balanced.
I did find out that you can lower the headlight 2-3" just by pulling the headlight mount tubes off the forks and switching them side for side. Then you can flatten the gauges by bending the gauge mounts to lower the "peaky" look of a stock setup. I am still going to do the clip ons to help this a little more. I am also reworking the aluminum rear peg mounts. I have them off and am going to make much smaller ones that are alot less obtrusive on the frame and bottom frame profile to make the bike look like it has a little more clearance in the middle. You can see in the pic of the LH side I have the peg mount off, and it looks SWEET! But the wife does need a place to put her feet...
Anyway, that is where the project is at. I am not JUST snowmobiling...
