pitted fork tubes
  • dontlikeoc
    • Nov 2009
    • 173
    • Alhambra, CA
    pitted fork tubes
    I know there is a previous thread. I am wondering how you are dealing with the problem. Did you all get new tubes from Forking by Frank? Or, is there any other way to deal with the problem ingenious XS gurus figured out? I heard that, in old days, the mechanics used to sand and smooth them so that they dont eat the seals.
    When I got the bike, the inner tubes were leaky but looked clean. I guess that the inner tubes sagged into the outer tubes so much to hide the pitted part...
    dontlikeoc
    1981 XS1100 Special Edition
    Alhambra, CA
  • mro
    • 4276
    • Hayward, California
    least XSpensive, find a good used set.
    mro
    • jmnjrpa
      • Jun 2009
      • 863
      • Lewisville, Texas
      Yeah, but I looked for a year and still could not find better than I had.
      '81 1100 MNS - "Midnight XSpress"
      Original except:
      Big John
      • dontlikeoc
        • Nov 2009
        • 173
        • Alhambra, CA
        John,
        In the meanwhile, are yours leaking?
        dontlikeoc
        Alhambra, CA
        • dontlikeoc
          • Nov 2009
          • 173
          • Alhambra, CA
          Forks from what other model are good for an XS1100 Special? I fear if this will turn out to be another case of X works for Standard but not for Special...
          As for the part numbers, does Yamaha do the same thing as Suzuki making part numbers different even though the two parts are the same if the machines they are used for are different?
          dontlikeoc
          Alhambra, CA
          • mro
            • 4276
            Keep your eye on craigslist or whatever local classifieds you have.
            Most XSes I got for $200.00 or less and got em all running except three of which one will be running someday.
            The tubes can be repaired, but have no idea what it would cost.
            Most likey cheeper to get em from franks?
            mro
            • jmnjrpa
              • Jun 2009
              • 863
              • Lewisville, Texas
              No, the pits are above normal travel. If you need to change out the seals get them from PnM or almost anywhere except Yamaha$$$.
              Original except:
              Big John
              • dontlikeoc
                • Nov 2009
                • 173
                • Alhambra, CA
                The sad thing is that I put on the new seals and then fount out the pits that were hidden in the level below the seals when the seals were broken.
                dontlikeoc
                Alhambra, CA
                • jmnjrpa
                  • Jun 2009
                  • 863
                  • Lewisville, Texas
                  It appears you are talking about the dust seals. The oil seals are inside the outer tubes. You have to remove the inner tube to replace the oil seal properly. In doing so you would have seen the pits. Your dust seals may still be good. You just need to replace the oil seals when you fix your fork crisis.
                  Original except:
                  Big John
                  • dontlikeoc
                    • Nov 2009
                    • 173
                    • Alhambra, CA
                    i am talking about fork seals, not the dust seals. Since I had to get outside help for something else, I had them do the fork seals for me too. Only after the job was done, the inner tube pits became visible as the part of the inner tube that were sagged into the outer tube with leaky seals rose up.
                    dontlikeoc
                    Alhambra, CA
                    • mxmikie
                      • Aug 2008
                      • 482
                      • Bouse az
                      the xs 1100 has 37mm forks here is a list of bikes that have 37mm forks........ 37 Honda CR-80R (96-98)
                      37 Honda CR-80R (99-02)
                      37 Honda CR-85R (03-04)
                      37 Honda CR-125R "Elsinore" (79)
                      37 Honda CR-125R "Elsinore" (80)
                      37 Honda CR-250R "Elsinore" (78-80)
                      37 Honda NX-250 (88-90)
                      37 Honda XR-250R (81-82)
                      37 Honda CMX-450C (86-87)
                      37 Honda CX-500TC (82)
                      37 Honda FT-500 "Ascot" (82-83)
                      37 Honda VF-500C "Magna" (84-85)
                      37 Honda VT-500C "Shadow" (83-84)
                      37 Honda VT-500C "Shadow" (85-86)
                      37 Honda XL-500R (82)
                      37 Honda CB-550SC (83)
                      37 Honda CBR-600F "Hurricane" (87-90)
                      37 Honda CB-650SC "Nighthawk 650" (82)
                      37 Honda CX-650T "Turbo" (83)
                      37 Honda VF-700C "Magna" (84)
                      37 Honda VFR-700F "Interceptor" (86)
                      37 Honda CB-750F (81-82)
                      37 Honda VF-750C "V45 Magna" (82-83)
                      37 Honda VF-750S "Sabre" (82-83)
                      37 Honda VFR-750F "Interceptor 750" (86)
                      37 Honda CB-900C "Custom" (80-82)
                      37 Honda GL-1000/K "Goldwing" (75-79)
                      37 Kawasaki EX-500D1-D11 "Ninja 500R" (94-04)
                      37 Kawasaki ZL-600A1/A2 (86-87)
                      37 Kawasaki ZX-600A1-A3 "Ninja" (85-87)
                      37 Kawasaki ZX-750A1-A3 "GPz" (83-85) 37 Kawasaki ZX-750E1/E2 "Turbo" (84-85)
                      37 Kawasaki ZX-1100A1 "GPz" (83)
                      37 Kawasaki ZX-1100A2 "GPz" (84)
                      37 Suzuki RM-85 K2-K4 (02-04)
                      37 Suzuki XN-85 D "Turbo" (83)
                      37 Suzuki GS-500 EK/EL/EM/EN/EP/ER/ES/ET (89-96)
                      37 Suzuki GS-500 EV/EW/EX/EY (97-00)
                      37 Suzuki GS-550 LD/LF (83, 85)
                      37 Suzuki GS-550 ED/ESD/ES3/ ESE/ EF/ESF/ESG (83-86)
                      37 Suzuki GS-650 MD "Katana" (83)
                      37 Suzuki GS-700 EF/ESF (85)
                      37 Suzuki VS-700 GLPG/GLEPG/ GLPH/GLEPH "Intruder" (85-87)
                      37 Suzuki GS-750 ED/ESD (83)
                      37 Suzuki GS-750 LN (79)
                      37 Suzuki GS-750 SD "Katana" (83)
                      37 Suzuki GS-850 GN/GT/GX/GZ (79-82)
                      37 Suzuki GS-850 GD (83)
                      37 Suzuki GS-1000 C/EC/N/EN/ET (78-80)
                      37 Suzuki GS-1000GT/GLT/GX/GLX (80-81)
                      37 Suzuki GS-1100 ET/EX/EZ (80-82)
                      37 Suzuki GS-1100 ED/ESD (83)
                      37 Suzuki GS-1100 GZ/GLZ (82)
                      37 Suzuki GS-1100 LT (80)
                      37 Suzuki GS-1150 ES3/ESE/EF/ESF/EF2/EG/ESG (83-86)
                      37 Yamaha XJ-650 LK "Seca Turbo" (83)
                      37 Yamaha XJ-900 RK "Seca" (83)
                      37 Yamaha XV-920 RH/RJ "Virago" (81-82)
                      37 Yamaha XJ-1100 J "Maxim" (82)
                      37 Yamaha XS-1100 E/F/G/H (78-81)
                      37 Yamaha XS-1100 LG/LH (80-81)
                      37 Yamaha XS-1100 LG/LH "Midnight Special" (80-81)
                      37 Yamaha XS-1100 SF (79)
                      • jmnjrpa
                        • Jun 2009
                        • 863
                        • Lewisville, Texas
                        Then all you need is the inner tubes from that list. I was looking for the whole fork assembly (much harder to find).
                        Original except:
                        Big John
                          Couple of Special sets on eBay now, but kinda pricey. Good sets come up pretty often for under $50.
                          • dontlikeoc
                            • Nov 2009
                            • 173
                            • Alhambra, CA
                            Are you suggesting that any inner tubes from Mikes 37 mm tube list are direct swap? Is it that easy with inner tube swapping?
                            dontlikeoc
                            Alhambra, CA
                            • DeanR
                              • Jan 2005
                              • 1499
                              • Finger Lakes NY
                              Fork seals are something that you want to stick with Yamaha for, not aftermarket.
                              80 SG
                              81 SH in parts
                              99 ST1100
                              91 ST1100
