swapping just rear wheels between xs750/1100
  • aaronxs400
    • Jan 2010
    • 1
    I am wanting to put the 16inch xs1100 wheel onto my xs750. I dont care about the final drive ratios between the two. That being said, will the xs1100 wheel bolt onto my xs750? if not what mods are required? I am wanting a 16/19 combo for a custom build im doing.
  • dontlikeoc
    • Nov 2009
    • 173
    • Alhambra, CA
    Isnt a wheel from XS1100 Special 16 inch, also?
    dontlikeoc
    1981 XS1100 Special Edition
    Alhambra, CA
    • tarzan
      • 1700
      • Chandler,Az.
      The one thing I think might be different is the rotor diameter.You may need to adapt the 750 brakes to it.
      Or, I wonder if the bolt pattern is the same and you could just swap rotors?
      I have an XS750 and a couple Xs850's as well as my XS11, so I can take a closer look a little later.
      Rick
      80 SG XS1100
      14 Victory Cross Country
      • cywelchjr
        XS-XJ Super Guru(Deceased)
        • 4450
        • Sacramento, CA
        I know that the front brakes are the same as the 11 standard, but I'm not sure about the back.
        • soccer4m
          • 694
          Yes
          Hi, check the thread on this, I have a xs750 rim on a xs1100, 1980, with no modifications needed. So the reverse should also be ok. I started the thread a year or so ago, the disadvantage is the xs1100 rim will turn a lot faster for the same speed. Good luck, Mike in Sun Diego
          mike
          1982 xj1100 maxim
          1981 venture bagger
          1999 Kawi Nomad 1500 greenie
          1959 wife
