Indian rope trick.....
Feed soft rope or shoelace into the sparkplug hole and then manually raise the piston to compress the rope against the valve. Do your thing, then you'll have to manually release the pressure to remove the rope.
Manual engine movement may be done by removing all sparks, 5th gear, move rear tire while on centerstand or push cycle forward or back as required.
I agree with remove the head and fix it all...... just wanted to impart the "trick" as it works well in a micro surgery situation.
Cheers! *(clink)*
Cheers! *(clink)*
