Carb springs 78 different from 80/81?
  • Snow
    • Oct 2002
    • 1041
    • Tallahassee, FL
    Hi all,
    Are the diaphram return springs in 78 carbs different from 80/81 carbs? The springs that were in my 78 carbs looks to be a couple inches shorter and diameter is about half the size of my other carbs.
    I looked up the yamaha part numbers and those are different from 78 and 80, but that doesn't necessarily mean I have the right springs in my 78 carbs :/
    • 5062
    I think I have a set of 80 carbs out in the garage. It is late tonight, but if you need to have me take the diaphragm spring out and measure it, I will at your request...tomorrow.
    Sid
    • Dennyz
      • 1151
      • Olympia, Washington
      Yes, the '78-'79 carbs have different slide springs than the '80-'81s.
      DZ
      Vyger, 'F'
      "The Special", 'SF'
      '08 FJR1300
      • Snow
        • Oct 2002
        • 1041
        • Tallahassee, FL
        Thanks guys, these are the only set of 78/79 carbs I have ever had my hands on and they were known to be not working right when I got them.
        Somewhere I had read something about someone trying XS650 springs in their XS11 carbs and noting that they were too short, so I wanted to make sure someone hadn't put 650 springs in mine while tinkering around.
