Ok here is the repost,
and the the response I already received from the other list.
I need to replace the fuse panel to correct one of the many woes from the po, some may remember my post 2 weeks ago about literally smoking the ign wire from the switch to where the po hard wired (no fuse) it into the system... the only thing that saved me was a poor connection melted and thus became the fuse.
I know that Indy rick used to do panels, and others have used different things, I'm still trying to beat the clock again for Big Island Deuce.. and i also think i have to replace the ign wire, but not sure if i have to split the harness due to any splices???
(one reply as follows)
> On Sat, 6 Jul 2002 15:35:34 -0700 "Michael Hart" <mdh@s...>
> wrote....
> Begin Quote:
> > Jeff, I got one from Schuck's for like $4. Next time you're over have
> > a look at how I did the XJ's fuse panel. It fit under the stock fuse
> > cover too ;>)
From Homer Parker:
> You wouldn't have any pictures of it, would you? I've got nylon tie-wraps
> in use at the moment, and think I might want something a bit more
> permenant.. Was thinking about using in-line spade fuse holders, but am
> open to other ideas..
> Homer Parker (The Bogus One)
> http://www.homershut.net
> telnet://bbs.homershut.net
> wrote....
> Begin Quote:
> > cover too ;>)
From Homer Parker:
