If I change the rear from 17" to 16" will I need to change the caliper support bracket?
16" rear question
I'm no expert randy, but there is no difference in the rotors, other than slotted or not, as far as I can tell so I wouldn't think rim diameter would make any difference there.
Like I said, I'm no expert. JAT -
When I put a 16" Special wheel on my Standard (both 79s), I needed a spacer to make the Special wheel fit. The spacer also made the Special caliper bracket not line up correctly, so I had to use the Standard bracket. I don't know if the Special bracket can be made to fit, but as I am not a very advanced fabricator I went with the route of least resistance.
Hope this helps.
Happy New year.
PatrickThe glorious rays of the rising sun exist only to create shadows in which doom may hide.
XS11F (Incubus, daily rider)
1969 Yamaha DT1B
Five other bikes whose names do not begin with "Y"Comment
I have not made the change either as all I have owned are specials. I would tend to agree with Greg (as painful as that was to see in print) that the rotors are interchangable and therefore should not make a difference.
The swingarm is the exact same part no from 1978 through 1981SH so the same on std and special models. So unless the wheel itself has a different thinckness at the hubs from the special to the std should be no change. I would think if there is a change in the thickness and you needed a spacer of some kind, I would put it between the caliper bracket and the swingarm.Life is what happens while your planning everything else!
78 XS750Comment
Here's a picture of the spacer I am talking about and also shows how I have the caliper bracket mounted. This is before I cleaned it up. The Special bracket did not line up, although I wanted to use it since it was in much better condition and the grommets were still flexible.
Maybe you can figure a way to make the bracket line up better.
1969 Yamaha DT1B
Randy,
I considered going to a 16 as I have had enough dealing with tubes, and tubeless rims are hard to come by. 16 in tires are more common on the road should you have to replace a tire on a trip. The major draw back to me was in dealing with the center and side-stands. The exhaust on my '78 is in the way for getting a good toe hold on the center stand making it a bitch. It is every thing I can do to get the beast on the center stand with a flat. With a flat tire, the side stand is useless. I figured a 16 would only make this worse. I finally found tubeless rims at a price I could live with - the wifes Christmas present to me thou she was a little surprised when they came a couple days before Xmas LOL.
Deny1978 XS1100E - The TimeMachine
1980 XS850 Special - Little MoComment
When I changed to a 16" rear for SWMBO's 'H, I ground a bit from the inside of the right side axle support, and used a spacer on the left side of the caliper bracket to get the caliper to center over the rotor. I posted a couple of photos in this thread.Ken TalbotComment
