HOW TO: xj11 gas tank removal?
  • tbcfreerider
    • Dec 2009
    • 85
    • Glendale,CA
    ok, so im starting to repair the bike, when i crashed the paint on the tank went to ****.
    so please if anyone can walk me through HOW TO
    1. properly drain the tank
    2. remove the tank
    3. wish me luck on removing the crap from the sensor
    thanks all!
    What you need to do is be thankful for the life you got. Stop looking at what you dont have and start being thankful for what you do have.
    82 XJ 1100
  • tbcfreerider
    • Dec 2009
    • 85
    • Glendale,CA
    oh and can anyone help identify this?
    82 XJ 1100
      Ok second question first as it is the quick and easy one, that is your auxillary fuse. I see someone upgraded your fuse box. Also looks like they might hav a wrong size fuse for your signal circuit, it is typically a 20 amp, but I am not as familiar with the XJ series. I typically take the wires form that auxillary fuse off and hook the gorund back to the same screw tp the frame, then take the hot and run it to one of the fuses in the new box.
      Question number one, I typically turn the petcocks to off which should stop the flow of fuel. If it don't then you can put a inch clamp of some kind on the fuel line, or bring your garage gas can to the bike and hold it up so you can drain the gas fron the tank into it before you remove the tank.
      Removing the tank is pretty easy, just pull the fuel lines form the petcocks, pull the bolt from the rear of the tank, pull the electrical connecter at the back of the tank on the right side (on the special model anyway) that connects your low fuel light/gage. Then pull up at the back and rearward on the tank and she will pull loose.
      And good luck on removing the crap from the sensor.
      • tbcfreerider
        • Dec 2009
        • 85
        • Glendale,CA
        what is the AUX for anywho? when i got the bike there was no fuse, i have it out and everything seems OK!?!?
        also i tried to undo the lines from my petcock and even with the switch in the off pos. one hose DUMPS gas out.
        82 XJ 1100
          I wired up the Aux on Tsunami for my handlebar-mount GPS unit. On SWMBO's 'H, we used it for a set of auxiliary fog lights.
            Answer, whatever you want to use it for that takes no more than 10 amps, and does not overdraw the alternator, which on this bike equals good frickin luck!
            Sounds like you need to rebuild a petcock, which means see the part about using a pinch clamp or something like it.
            • tbcfreerider
              • Dec 2009
              • 85
              • Glendale,CA
              but where does that plug off the back goto... there is a male end, but i didnt notice anything diff
              82 XJ 1100
                Somewhere around that area is the matching connector. It also has a red a black wire to it and comes from the harness. Should be the only connector that looks just like it in that spot.
                • tbcfreerider
                  • Dec 2009
                  • 85
                  • Glendale,CA
                  ok , when i got the bike, i was told that the fuel gauge wouldnt work... I got the tank off and am preping it for paint... in the mean time, this is the gauge:
                  AM I MISSING ANYTHING FROM IT?
                  if you can txt me@ 626.931.9565. im gonna be out painting. thanks
                  82 XJ 1100
                    • 7831
                    You do NOT have a float on the end of the arm!! Go to the auto parts store and look at a "universal" fuel gauge. You will see a float on the end of the arm. Try to get a "cheap" universal kit, and use the float from it to put on your gauge. That should fix it!
                    • tbcfreerider
                      • Dec 2009
                      • 85
                      • Glendale,CA
                      thats what i was thinking my self.
                      82 XJ 1100
                      • tbcfreerider
                        • Dec 2009
                        • 85
                        • Glendale,CA
                        think i can make one?
                        82 XJ 1100
                          • 7831
                          It NEEDS to be able too live in gasoline for years! If it's NOT made from brass or steel, it may not last. It would be MUCH easier to find a float out of almost anything, and use it. Try a boat shop, and see if they have a "replacement" float for one of the outboard gas tanks. They will be made of the type of plastic needed to resist the gas. JAT
