? about ballast resistor
  • freebird01752
    • Jun 2003
    • 66
    • Marlborough, Mass 01752
    Hey Guys,
    I have a 1980 XS1100SG and found out the ballast resistor is being by-passed. What problems will this cause to the bike?? Right now that bike runs great.
    Thanks,
    Steve
    1980 XS100 SG Gone but not Forgotten really wish I could have kept it
    1998 Suzuki VS1400 Intruder
  • xssiveone
    • 766
    • Windsor,Ontario,Canada
    Re: ? about ballast resistor
    The ballast resistor is there to stop the coils from burning out, and you should take steps to put it back into the circuit.
    The coils don't require full voltage to run the engine. When you hit the starter button, full voltage is applied to the coils to give a hotter spark for startup. Once the engine has started, and you release the starter button, the circuit switches over so the current passes thru the ballast resistor, which reduces the voltage to the coils. Not sure by how much, I have heard by as much as half.
    Brian
    remembering the same thing!
    • freebird01752
      • Jun 2003
      • 66
      Xssiveone,
      thanks. I have a new one ordered and should be here soon. Just wanted to know what problems this could cause. The PO had done this for what reason I do not know. And for how long it has been that way. I found out about it because I dropped a nut down on the heads and the cover to the resistor was laying next to the spark plug. When I took the screw out of it. It fell off and the wires were connected back to it self.
      Hopefully no damage to the coils have been done as of yet.
      Steve
      • sixtysix
        No XS but XSive as can be!
        • 1958
        • Central New York State
        There may be a different than stock set of coils in it and maybe he didn't feel he needed it anymore? Who knows.
        Gary Granger
        • freebird01752
          • Jun 2003
          • 66
          Sixtysix,
          Is there any way to tell if the coils are stock. And if they are different would putting the resister back in.
          Thanks,
          Steve
          1980 XS1100SG
          • sixtysix
            • 1958
            This thred on repairing coils shows the stock coils. After markets are usually bright green, red or yellow. I think the coils with higher ohm primaries (like 2.5 to 3.0 ohms) are good without the resistor, but the stock ones with 0.7 ohms (?) probably need it. I am not real an expert though.....
            Gary Granger
