xs carbs
  • SFSPECBIKER79
    • Jul 2008
    • 403
    • NC
    xs carbs
    what other models of carbs will fit a xs 1100 79-80 year? without modifications. thanks for your help.
    79 xs 1100 spec & 80 xs 1100 g
    • 8054
    XS650s run Mikuni BS34s, but only in pairs and they aren't jetted the same. Earlier XS650s run BS38s.
      XS400's also use the BS34's with different jetting. I believe that on both the 650's and 400's that the slide springs are different than on the 1100's also.
        • 8054
        Mine still isn't running right, as I have a part power dropout. I used the XS650 carburetor body with all the stuff from my original carb stuffed into it.
        • GARTHXS
          • Nov 2007
          • 1631
          • Seattle
          fj carbs
          I have 85 fj1100 carbs on my 78 with minimal
          Mods just a bar mounted choke and slight mod on the throttle but other than that only a fuel T because the inlet on the carbs are 5/16
          91 kwaka kz1000p
          Stock
          ( Insert clever quote here )
