Dumb Question from me today!
I have a late XS with the octopus fuel line arrangement. Been having some real hassle in getting it running properly and took off the octopus around six months ago which seemed to improve things.
Have recently installed new float valves, which I've found need some adjustment as fuel is still getting through the carbs and ending up in the sump with the oil.
I'm going to take my carbs off (again!) this weekend and get the float height right across the lot corrected and am thinking of putting the Octopus thing back into service.
So - my question(s).
I've seen some contradicting information on how the fuel lines connect up between the octopus and taps. Has anyone got the definitive guide?
Is it a simple job of setting the tap to prime - looking where the fuel comes from and connecting the carb supply line up to this and vacuum side on the other connection to the fuel tap?
I'm a little sceptical about putting back the octopus - does anyone have advice on if it's a good idea or not.
Cheers - Graham
Cheers - Graham
