will this work?
  • SFSPECBIKER79
    • Jul 2008
    • 403
    • NC
    will this work?
    I seen some carbs listed as: mikuni GS BS34 1100 Will these fit and work on my 80 xs 1100? and has any one here had any dealings with seller oldschoolcarbs on ebay. The carbs look exactly like the ones i have now, just don't want to be stuck with carbs. i can't use. thanks for any input on this.
    79 xs 1100 spec & 80 xs 1100 g
    • 8796
    If they're for a GS Suzuki, you might run into problems with the spacing of the carbs lining up with the intake boots.
    07 Triumph Tiger 1050
    • TomRodgers
      • Jun 2008
      • 492
      • La Porte Indiana
      Phil....
      even if they are spaced wrong, couldnt you swap the carb bodies from that setup to the rails from an XS ???? JAT....
      I would simply ask "oldschoolcarbs" to enusre that they fit. and if for some reason they dont, ship them back. you could also ask for measurements and compare....
      '81H (my first XS ) "Grey Ghost"
      4:1 Jardine w/ headerwrap
      Windjammer(wiring issues)
      New paint/brakes to come!!
      '80G FrankenBike (parts bike)
      '80G to fix "BlackSunshine"
      Stock Pilots/125 mains
      Pod filters; 4:1 Kerker??
      SS Brake lines w/ new M/C's
      LED Brake Lite
      Needs paint....
        • 8796
        Don't know the answer to that, it would probably be a hassle tho.
        • TomRodgers
          • Jun 2008
          • 492
          • La Porte Indiana
          i never said it would be EASY.......
          LED Brake Lite
          Needs paint....
