The shim size you need depends on TWO things. ONE is the current gap, which you have measured. TWO is the current shim size. So you need to check the shims currently in place before you can figure what size shims you need.
Valve clearance changes as the valve wears into the seat in the head. On these engines, the gap will close up as the valve wears into the seat. Manual indicates to check the valve clearance every 5,000 miles. So they must expect some wear in that interval.
