Oh Snap-transmission
'79 XS1100 (2H9) named Bones
1196 Big Bore
4-1 Cowley exhaust
750FD Conversion
Echlin 54mm Racing Cones (Americanese = pods)
Black Ebony Bottled glazed Tank (To be redone now)
BMX footpegs
Tank internally lined (Professionally this time)
GSX400 Throttle bodies (Under serious investigation)
Anti Sticky float bowl system -
"For those of us with the engine completely out of the bike with nary a wheel or a rear brake to help keep things still, how is this procedure done?"
You either leave the cover off until you put the motor back in the frame, or you find a way to jam the middle drive output w/o damaging anything.
Sometimes a well placed penny between a couple of gears can do the trick, although I can't recommend this as defacing gov't property is illegal
'05 ST1300
'83 502/502 Monte Carlo for sale/tradeComment
There is a special tool for holding the clutch basket so the nut can be removed with the engine on the bench. I bought one 20 years ago, when I went to use it, I twisted it into a pretzel
. I ended up carefully chiseling at the nut until it collapsed. Hope you don't have to go this far. Try an air impact gun.
☮Comment
With the engine out of the bike, there's still some resistance to sudden movement in the clutch pack.. that's why an impact works. I've always tightened that nut up best I can by holding it, then taken a rubber hammer to the ratchet handle. A few whacks and it's pretty darn tight. Maybe not torqued exactly correct, but I've never had a problem in all the motors I've done this way. Just make sure to bend the edge of that washer back up against the nut.
