Fork geometry
  • ruffrider
    • Mar 2008
    • 60
    • Stanwood, Washington
    Fork geometry
    Does anyone know if the XS650 forks are the same dimensions as the Eleven?? I want to know if a fork brace from a 650 will work on a XS1100.
    1979 XS 1100 SF(16k now, more to come)
    140 mains, 42.5 pilots, drilled airbox w/uni fliter
    MikesXS Coils- bypassed ballast resistor- new wires
    1975 GL1000 Gold Wing(81k-Old Faithful) and another 75 GL1000 project. MBS sickness for sure.
    Other Bikes Iv'e owned:
    1979 Kawasaki 750 LTD
    1980 Kawasaki 125 Enduro
    1975 Honda 400f
    1976 Honda CB360
    1968 Honda 160
  • Montreux_Blue
    XS-XJ Guru (Deceased)
    • 1143
    I think all XS650 forks are setup like a Standards forks, the wheel is mounted at the bottom of the tubes, so it would probably work on a Standard.
    Famous Myspace quote:
    • tinman905
      • Aug 2007
      • 946
      • Orangeville,Ontario ,Canada
      The 650 forks are 35mm . The 1100 down tubes are 37mm I would think it won't work .
      BDF Special
        • 8863
        If the brace fits to the fender mounting bolts, maybe. If it bolts to the legs at the top by the dust boots, I'd say no.
          • 7795
          For less than $100 you can get a fork brace from TKat that FITS and WORKS. why play around???
          • GARTHXS
            • 1631
            • Seattle
            maybe
            I think a couple of members have one , one is KORR and THE WIZ , they both have standards
            91 kwaka kz1000p
            Stock
            ( Insert clever quote here )
            • ruffrider
              • Mar 2008
              • 60
              Thanks for the replies guys. I'm going to give it a pass. It was on FleaBay for 15 bucks NOS. So if you know of anyone with a 650 maybe they could jump on it. Search for: Fork Brace, Tweek bar for Yamaha 650 CC
              1975 Honda 400f
              1976 Honda CB360
              1968 Honda 160
