Rear brake light HELP!
  • tbcfreerider
    • Dec 2009
    • 85
    • Glendale,CA
    So I did use the SEARCH...and read a few things but feel I came up empty.
    My rear brake light only comes on with the had brake lever NOT the foot brake. ANY thoughts?
    82 xj11
    What you need to do is be thankful for the life you got. Stop looking at what you dont have and start being thankful for what you do have.
    82 XJ 1100
  • TomRodgers
    • Jun 2008
    • 492
    • La Porte Indiana
    Any ideas.....on this site.......ahhhh ROOKIE!!!!
    My guess is that there is either a broken wire from your rear brake switch, or it is WAY out of adjustment, or the wires from the foot brake switch are not connected in the rear assembly. remove the 'tag' bracket and check all your connections. i had a similar issue. due to the lights operating from front and back, there is a "y" bullet connector. the side for the rear was loose. i had to pinch the female end a bit (and she didnt slap me!!!) and shove the male end in deep viola..... rear brake light!!! just my $.02 good luck!!
    4:1 Jardine w/ headerwrap
    Windjammer(wiring issues)
    New paint/brakes to come!!
    '80G FrankenBike (parts bike)
    '80G to fix "BlackSunshine"
    Stock Pilots/125 mains
    Pod filters; 4:1 Kerker??
    SS Brake lines w/ new M/C's
    LED Brake Lite
    Needs paint....
      Originally posted by tbcfreerider
      - - - My rear brake light only comes on with the hand brake lever NOT the foot brake. ANY thoughts? - - - 82 xj11
      Hi free,
      well, you know the bulb is good. Find the footbrake stoplight switch, pull the wires off it and bridge them together. If the stoplight don't work when you do that it's a wiring problem. If the stoplight does work, the problem is in the switch but the wires are OK.
      Check the switch by manually shoving the switch operating rod all the way across. If the stoplight works then, the operating rod needs to be adjusted. If it don't, the switch internals are dirty or broken.
      • tbcfreerider
        • Dec 2009
        • 85
        • Glendale,CA
        hahaha... thanks for the dirty and clean truth.. i will check it out when its not raining.
        82 XJ 1100
        • tbcfreerider
          • Dec 2009
          • 85
          • Glendale,CA
          Hi free,
          IM SOOOO CONFUSED! iM A TOTAL ROOKIE TO WORKING ON MOTORCYCLES... ANY PICS?
          82 XJ 1100
            • 7818
            No pics, but if you look at the rear brake lever you will see a small spring going up to a plastic bit with two wires going out of the top. That is the rear brake light switch. Unplug the two wires from the switch, and touch them together with the ignition switched on. If the brake light comes on, the wires are good and the switch is bad. This is the most likely problem, but the switch is a bear to get out sometimes. You can buy a replacement from ebay for about $15 to $20. HTH
            • tbcfreerider
              • Dec 2009
              • 85
              • Glendale,CA
              Ok that makes since... I noticed that spring is really haggard!
              82 XJ 1100
                Baby steps
                Hi free,
                first, check this out:-
                A multimeter is an instrument used to check for AC or DC voltages, resistance and continuity of electrical components, and small amounts of current in circuits. This instrument will let you check to see if there is voltage present on a...
                then go buy yourself a multimeter. A cheap one ( ~$20 ) will do for working on a bike. Practice with it by checking the a.c. Voltage in power outlets, the d.c.Voltage of batteries and the Ohms resistance of lightbulbs.
                Armed with your newfound knowledge and your shiny new multimeter, trot out to look at your bike.
                Turn on the ignition, squeeze the front brake lever to see the stoplight work then push the rear brake pedal down to see the stop light NOT work.
                This confirms the condition as you have described it.
                Lean the bike on it's side stand and remove the right-hand plastic side cover so you can see things better.
                Now get a crawl mat and lay down so you can see the rear brake pedal where it works the rear master cylinder.
                You should also see a tension spring pulling a rod that comes out of an electrical switch that is bolted to the bike frame. That's the rear light switch.
                You should be able to find a two-wire cable sheath with a green/yellow wire and a tan wire in it.
                Those two wires should end in female spade connectors that plug onto the switch.
                First, check that both of the spade connectors are pushed onto the switch.
                If no, push on and check if the light now works.
                If yes, pull the tan wire off the switch, set the multimeter to read d.c.Volts and check between the terminal and ground.
                The tan wire should have 12V on it when the key is on.
                If not, there's the problem.
                If there is 12V on the tan wire, set the meter to Ohms and check the green/yellow wire. That's the wire that feeds power to the brake light. You should see an Ohms reading to equal the Wattage drain of the brake light filament.
                If the tan wire has power and the green/yellow wire shows resistance, bridge the two spade connectors together with a short piece of wire to see the brake light come on.
                Now check the resistance between the two switch terminals.
                With the brake pedal at rest, the switch should be open, having an infinite resistance reading.
                Push the switch all the way across. The switch should close to give a zero resistance reading.
                If the switch will not conduct power (stays at infinite resistance) when it is manually activated) it's not working, it's most likely unfixable and needs replacing.
                If the switch works, plug the wires back on and work it manually once more, if the brake light works when the switch is operated manually the pedal is not pulling it far enough to work as you ride.
                There's an adjustment screw on the back of the switch.
                Mebbe try that first?
