Spoke to a guy today who mentioned the following:
You take your old rubbers and grind them off just before the aluminum base. The way I understood is that the aluminum base has a piece of pipe attached to it going into the rubber. You then clean it of to almost against the pipe. Make a groove for an O-ring, then use normal Suzuki round Carb rubbers on there.
Everything sounds good, but here is my questions that you guys can maybe answer:
1) Does the distance from carb to head play a part in the gas atomization?
2) If it does play a part, would it improve atomization or decrease it?
3) How far does the Aluminum pipe attached to the base come out?
4) Anyone heard or tried something like this?
